Car wont start, please help (all info inside) ek/w b16
Old Sep 23, 2006 | 08:36 PM
B18C GSR CIVIC's Avatar
Default Car wont start, please help (all info inside) ek/w b16
So in the end it was just the coil in the dizzy :S
Fixed, pics of new beast up soon
Modified by B18C GSR CIVIC at 11:00 PM 9/25/2006
Old Sep 23, 2006 | 09:04 PM
Jhonny Ricer's Avatar
Default Re: Car wont start, please help (all info inside) ek/w b16 (B18C GSR CIVIC)
id say check your gap this is a cause sometimes when someone does a swap they forget to check the gap on the spark plugs and see if they are off even though you have spark it doesnt mean your car will start
check the timing this could have been thrown off how i dont know but if i have problems i usually double check timing to make sure its right on
maybe for some reason your mixture is to rich or to lean not allowing it to start initially
just my two cents
Old Sep 23, 2006 | 09:24 PM
ham's Avatar
ham
my friends GSR did the same exact thing: it ended up being the coil in the dizzy. also, we did the checks with the ohmmeter and it was in spec, tried changing it out anyways, and it fired right up!
also, did you do your compression at WOT? every fresh b16 ive seen had 200-220 psi compression.
Old Sep 24, 2006 | 12:08 AM
hybridb18's Avatar
you need octane boster, its got a swap its fast dawg
Old Sep 24, 2006 | 02:50 AM
nighttrain33's Avatar
Default Re: Car wont start, please help (ham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">my friends GSR did the same exact thing: it ended up being the coil in the dizzy. also, we did the checks with the ohmmeter and it was in spec, tried changing it out anyways, and it fired right up!
also, did you do your compression at WOT? every fresh b16 ive seen had 200-220 psi compression.</TD></TR></TABLE>
In my manual, the peak specs were 184 psi.
-Shane
Old Sep 24, 2006 | 03:29 AM
lv6l's Avatar
happen to me. turn out it was my dizzy. i swap out the ignitor and that other thing(can't think of it at the moment, but it's common for hondas for those to go bad)
Old Sep 24, 2006 | 06:29 AM
Default Re: (lv6l)
Thanks guys. Ill tow it to the shop monday. Also I dont believe tha if I had a bad ignitor or coil that I wold have spark. The swap has been in the car for 2 years so Its nothign fresh from that.
The compression is great at 180 on a cold motor.
What else......... i dont know :S
Old Sep 24, 2006 | 08:27 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: (B18C GSR CIVIC)
hmm.. fuel, spark, compresion, i'd say its the ecu... firing order is right i would guess.. im gonna go with ecu..
good luck bro, welcome back btw
Old Sep 24, 2006 | 10:00 AM
Default Re: (GarageAlchemist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarageAlchemist &raquo;</TD></TR><TR><TD CLASS="quote">hmm.. fuel, spark, compresion, i'd say its the ecu... firing order is right i would guess.. im gonna go with ecu..
haha, thanks man!
I though it could be either starter even though its turning over but not really. I hope its not the ecu bt I guess all we can do is stick in another obd1 and see but my money is gonna say its the dizzy. All my honda years taught be alot but I think its still possible to have spark but have something else fuc#ed in the dizzy to cause it nt to catch or so I think :S
and ofcourse there is no check engine light so :S
Old Sep 25, 2006 | 02:00 PM
Old Sep 25, 2006 | 06:12 PM
ham's Avatar
ham
Default Re: Car wont start, please help (B18C GSR CIVIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C GSR CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">So in the end it was just the coil in the dizzy :S
Fixed, pics of new beast up soon </TD></TR></TABLE>
I KNEW IT!
Geddy
13
Aug 26, 2014 10:50 AM
h22swapedsol
Sep 14, 2007 02:24 PM
SI_niki
Jun 18, 2004 08:00 PM
RussHondaCRXVtec
Dec 17, 2003 04:13 PM
KLN
Dec 30, 2002 11:56 PM
