still having same probs with car not starting...please help again...
Old 06-18-2004, 04:15 PM
SI_niki's Avatar
Default still having same probs with car not starting...please help again...
ok, my 93 delsol si w/ jdm b16 still wont start. got orange/yellow spark from spark plugs, crank bit wont start. alot of you pointed me too a new disty, so i bought one. still orange spark, still wont start. everything seems to be right tho, new plugs and wires, grounds grounded, wiring seems right, ect. would off timing cause it to spark orange and not start? how about weak battery? can you check and fix timing if the cars not running? oh and is the coil part of the disty? if not wheres it located so i can check it? im running out of ideas on why it wont start. anyone live in pa wanna help? thnks in advance!
SI_niki is offline
Old 06-18-2004, 04:49 PM
TrickHonda98's Avatar
Default Re: still having same probs with car not starting...please help again... (SI_niki)
there could be lots of reasons its not starting.
Bad Fuel mix?
(IF YOUR DELSOL has a ignition coil)
check to see if the coil cable is still attached, or resistance wire is still attached,
open it up and see if the winding has detached?
running rich or lean?
check your piston rings, letting air/fuel to leak past?
try your ignition mod.
go get an ecu diagnostic and see if there is anything there.
there are lots of things that can be wrong. keep looking.
Modified by TrickHonda77 at 9:01 PM 6/18/2004
TrickHonda98 is offline
Old 06-18-2004, 05:06 PM
handa's Avatar
Default Re: still having same probs with car not starting...please help again... (TrickHonda77)
me and my buddies just did my jdm b16a gen2. it won't start, so i bought new distributor and it still won't start. then we checked the timing belt...it was off. we adjust it right, and it starts like a charm.
maybe this might be the same case. check your timing belt timing.
handa is offline
Old 06-18-2004, 05:56 PM
SI_niki's Avatar
Default Re: still having same probs with car not starting...please help again... (handa)
ok, timing huh. we thought that may be it. heres a new problem, we have no idea how to do it at all. how do you check to see if your timings off and if it is how do you fix it? need step by step instructions and what all ill need.. or a website or post on here thatll tell us all that. thanks again!
SI_niki is offline
Old 06-18-2004, 06:01 PM
handa's Avatar
hold on let me check things out and show you...brb
EDIT:
ok before you start, you should open up the timing belt covers. there should be 2 bolts holding on to it.
it should come out and you'll be able to see the belt and the 2 cam gears like so:
notice in RED, the word "UP". Those should be in the same or close to the same angle as possible. mine was off alot and i had to adjust it with a friend.
if yours is off, you can read on.....
you'll need to open your valve cover. once it's open you'll have to slide the timing belt out of the 2 cam gears. getting the belt off is easy, but putting it back on will be harder.
once the belt is off the cam gears, you can adjust the cam gears so the "UP" lines up each other. Then you'll have to reverse the steps. i recommend having a friend help you out with putting the belt on the gears. when i did it, we both use just our hands.
good luck!
Modified by handa at 9:23 PM 6/18/2004
handa is offline
Old 06-18-2004, 06:05 PM
dogfood's Avatar
honda tuning actually just did a write up on how to change the timing belt on a d16, that should get you pointed in the right direction
dogfood is offline
Old 06-18-2004, 07:43 PM
SI_niki's Avatar
Default Re: still having same probs with car not starting...please help again... (dogfood)
ok well we actually checked that before and the arrows are in the same direction, so that means my timing belts ok right? i dont have an external coil do i? i just bought a jdm disty and im pretty sure its internal so it new and good. unless theres another coil im not aware of?? im really appreciating ppls help and suggestions! keep the suggestions coming, i dont wanna get banned for posting this again in the future!
SI_niki is offline
Old 06-18-2004, 07:51 PM
ABK
ABK's Avatar
you also wonna match up the timing with crank, cam gear pointing down, and crank on the white line.
ABK is offline
Old 06-18-2004, 08:00 PM
Default Re: still having same probs with car not starting...please help again... (ABK)
check your ignition relay
allmotorteg_96 is offline
scotty.b16a1
01-02-2013 04:54 AM
bestcivic
08-11-2009 08:20 AM
Cpt Ben
10-14-2006 12:34 PM
kell211
05-24-2005 10:50 PM
SI_niki
11
06-13-2004 05:02 PM
Quick Reply: still having same probs with car not starting...please help again...
  • Ask a Question
Question Title:
Description:
