starting issue...
hey guys, i have an 89 civic std and im having a starting issue. when i turn the key to start it, nothing happens. i am able to bump start it though. im not throwing any codes. everything is hooked up, all the fuses are good, all the grounds are good, battery is new, cables are new, im stumped. something strange though, when i turn the key to the 'on' postition, i can hear the MAP sensor click like the main relay, is that normal? any help is appreciated
thanks in andvanced
thanks in andvanced
it doesnt do anything, as i said in my first post.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamRedline89Hatch »</TD></TR><TR><TD CLASS="quote">hey guys, i have an 89 civic std and im having a starting issue. when i turn the key to start it, nothing happens.</TD></TR></TABLE>
the connections are good, ive checked them at least 4 times.
ignition switch is new, Maybe 6 months old. i checked all my grounds, they are all good and connected, valve cover, t-stat, battery, and tranny. im not even getting a click, i turn the key and i get nothing.
try jumping the terminals on the starter hook a wire from the BIG pos wire on the starter to the small spade terminal, if that doesnt do anything you need a new wire from the battery to the starter, it might be broken inside and not giving enough power the starter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamRedline89Hatch »</TD></TR><TR><TD CLASS="quote">ignition switch is new, Maybe 6 months old. i checked all my grounds, they are all good and connected, valve cover, t-stat, battery, and tranny. im not even getting a click, i turn the key and i get nothing.</TD></TR></TABLE>
Did you replace the key part or the wiring part of the Ignition switch?
The wire harness part of it goes bad and will act like that.
Jack Murphy
Jun 21, 2017 06:23 PM
