Del Sol VXi speedo problem.
Old Sep 22, 2006 | 11:40 PM
stupendo's Avatar
Default Del Sol VXi speedo problem.
I have a weird problem where the speedo on my car doesnt work first thing in the morning. If I drive it for say 20 minutes then stop for 20 minutes it starts working again. If I drive for 20 minutes and stop for 5 minutes it will still not work.
Does anyone have any ideas?
Oh yes its a 93 Del Sol Vxi.
Old Sep 23, 2006 | 01:15 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Del Sol VXi speedo problem. (stupendo)
if you get a CEL 17, VSS unit is bad or just a bad connection (common bad connection)
no CEL = speedo head is going bad.
Old Oct 8, 2006 | 03:47 AM
stupendo's Avatar
Default Re: Del Sol VXi speedo problem. (Mista Bone)
Cheers for that, finally got around to testing and yes I get a CEL 17.
Next question where is the VSS unit located. Sorry for being such a dumbass, hopefully I can solve this myself without taking it into a garage.
Old Oct 8, 2006 | 08:50 AM
axtran's Avatar
VSS is on top of the transmission. facing the engine, look towards the top left (to the passenger's side of the firewall, then look down
you'll see a plug that is vertically up from the transmission, 3 pin plug
sometimes its the vss unit that goes bad, and other times the wire gets corroded by water or stuff like that and it goes bad. good luck!
(its held on by i think two 10mm bolts to the tranny so u can take it off easily)
Old Oct 15, 2006 | 03:39 AM
stupendo's Avatar
Default Re: (axtran)
I think I have found it, here is a photo could someone confirm that it is actually this?
Cheers for all your help so far.
Old Oct 15, 2006 | 05:27 AM
t0p_sh0tta's Avatar
Default Re: (stupendo)
That's it.
Bipolarcivic
12
Mar 27, 2016 03:34 PM
Dripp_City
Oct 30, 2013 01:18 PM
vaptuning
Feb 18, 2010 08:13 PM
1slowcrx
Oct 26, 2008 09:28 AM
dr_liver_bones
16
Dec 7, 2005 07:38 PM
