Japanese EG Sir 2 B16A swap into Canadian EG2 - Error codes
Old Sep 22, 2006 | 11:52 AM
ogawa_jiei's Avatar
Default Japanese EG Sir 2 B16A swap into Canadian EG2 - Error codes
Edited
Old Sep 22, 2006 | 12:12 PM
Relic1's Avatar
the codes are based on the ECU not the engine.
5 - vacuum leak
6 - water temp sensor
the vacuum leak will cause high idle
the water temp sensor will cause it to run rich all the time which will make it idle high or simply poor.
Old Sep 22, 2006 | 01:16 PM
ogawa_jiei's Avatar
Default Re: (Relic1)
Edited
Old Sep 22, 2006 | 01:29 PM
sohcvtec1995's Avatar
cap that vacume line. also if your brake booster is going down, then you may want to lookinto replaceing that.
Old Sep 22, 2006 | 01:42 PM
Relic1's Avatar
the map sensor on the TB is not even connected.
the hose you are refering to looks like it's an external map sensor from your old TB. All though I can't read what the label says on top of it. So I could be dead wrong.
Old Sep 22, 2006 | 02:01 PM
ogawa_jiei's Avatar
Edited
Old Sep 22, 2006 | 04:22 PM
ogawa_jiei's Avatar
Default Re: (ogawa_jiei)
Edited
run for cover
Apr 30, 2012 07:43 AM
Hypermax
Jun 15, 2009 10:21 AM
kb0821
Feb 8, 2008 03:02 PM
B16A JDM EG
Apr 3, 2007 04:10 AM
Boostedb20EH2
Mar 5, 2007 06:41 PM
