92-95 B16a high idle
Old Jun 13, 2009 | 10:53 AM
Hypermax's Avatar
Default 92-95 B16a high idle
Hey i put a b16a in my 92 HB and i put all new **** in the TB and intake gasket and its still high when i did my swap i didnt change my map sensor i dont know if i need too
Old Jun 14, 2009 | 06:43 AM
KWayRacing's Avatar
Default Re: 92-95 B16a high idle
Start with a throttle cable adjustment then an idle adjustment. Check for vacuum leaks. These 3 are good places to start not necessarily replaceing parts. Map sensor failure is not a likely suspect of a high idle issue. I would not replace it.
Old Jun 14, 2009 | 10:03 AM
Hypermax's Avatar
Yea i already checked vacuum lines and adjusted the idle screw and cable any other ideas? is their away to tell if map sensor is nfg
Old Jun 14, 2009 | 05:56 PM
delsolproblems's Avatar
Is the screw adjusted to a completely closed throttle plate and it's still idling high? If not, what happens when you adjust the TB too far closed? Check the MAP sensor voltage at the closest to idle rpm that you can get. If it's not in spec and you can't find a leak, you'll want to check the system with a vacuum gauge. If the MAP sensor voltage doesn't correspond to the amount of vacuum that the gauge reads, then the sensor is bad. Also, is there any rpm bouncing?
Old Jun 14, 2009 | 06:39 PM
civic95hbvtec's Avatar
Could be TPS
Old Jun 15, 2009 | 10:02 AM
Hypermax's Avatar
Wooooo fixed it i put a b18a TB on the b16a and 1000 idle now just gotta go re time it thanks guys it must have bin the TP sensor on it
Old Jun 15, 2009 | 10:21 AM
crxlsvtech's Avatar
New User
b18 TB on b16 Intake manifold is the best corrrection your all dumb checking the map voltage is a waste of time those sensors never ever fail ever your all baddies except for a few of you go jack off and learn about cars properly IM GAY
twocross
29
May 3, 2011 01:03 PM
accord2civic2prelude
Sep 6, 2008 09:51 AM
heyitzspikey
Jan 29, 2007 09:19 PM
talley2191
Jan 31, 2006 07:13 PM
Ryanwb
Mar 31, 2003 03:41 PM
