IAB Butterflies question?
Old Sep 22, 2006 | 10:38 AM
.BigSexy's Avatar
most hood white kid
Default IAB Butterflies question?
Ok, so my car seems sometimes a little sluggish, like it has lack of torque. It is an h22 4th gen. Well, when doing the h22 insall, I noticed there was a plug left over that didnt plug up anywhere,. It was right next to the knock sensor, but I have it plugged up. Well, my friend was telling me there should be a black box under there, and that is was runs the IAB's. so my question is, is this in fact the plug that is supposed to plug up to the black box under the IM, and secondly, will it throw a code, b/c I have not been throwing a code, other than a 5 and 23, which are knock sensor and MAP sensor.
Old Sep 22, 2006 | 10:40 AM
Hawkze_2.3's Avatar
Default Re: IAB Butterflies question? (egcoupe94)
No, it will definately not throw a code and that plug could have been for the IABs for sure...
Old Sep 22, 2006 | 10:43 AM
.BigSexy's Avatar
most hood white kid
Default Re: IAB Butterflies question? (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">No, it will definately not throw a code and that plug could have been for the IABs for sure...</TD></TR></TABLE>
now, there were two plugs. it seems like they both fit into the knock sensor. 1 reached just to the knock sensor, while ther other is about 1.5-2 inches longer.
how many wires go to the plug on the IAB's? is is 3 wire plug? and the knock sensor is a 1 wire plug, correct?
is there a plug on the black box on the underside of the IM?
Old Sep 22, 2006 | 03:56 PM
92_VTEC_lude's Avatar
here is a diagram of a complete IAB Control system from my repair manual, hope it'll help you to see which part you are missing from the system. You need to complete the system so it will close the flapper on the secondary intake under low RPM = more torque at low RPM.
incase that you find the part under the IM here is a vaccum diagram can help you to connect the right hose to the right hole.
Old Sep 22, 2006 | 03:58 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">Ok, so my car seems sometimes a little sluggish, like it has lack of torque. It is an h22 4th gen. Well, when doing the h22 insall, I noticed there was a plug left over that didnt plug up anywhere,. It was right next to the knock sensor, but I have it plugged up. Well, my friend was telling me there should be a black box under there, and that is was runs the IAB's. so my question is, is this in fact the plug that is supposed to plug up to the black box under the IM, and secondly, will it throw a code, b/c I have not been throwing a code, other than a 5 and 23, which are knock sensor and MAP sensor.</TD></TR></TABLE>
your car could also be running sluggish from the other codes it's
throwing as well.
Old Sep 22, 2006 | 04:12 PM
.BigSexy's Avatar
most hood white kid
Default Re: IAB Butterflies question? (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">
throwing as well.</TD></TR></TABLE>
yeah...but i havent driven my car since the MAP sensor thing, i was trying to rewire the plug to lengthen the plug, and I clip a wire, and the plug shoots somewhere in the grass, and I have yet to see it.
I do think the knock sensor may have something to do with it. It runs in limp mode right?
and thanks for the diagram man, that helps out a lot, anow I just have to figure out what I am missing.
Old Sep 22, 2006 | 05:26 PM
ExplicitSpeed360's Avatar
Banned.
check out the other post thats made about the p28 ecu and h22a I have a diagram and how to on actuating the secondaries (IAB's) to the Vtec solenoid so when Vtec kicks your secondaries open.
The sluggish problem could be because your secondaries are open all the time...my car when the secondaries were wide open (not connected, NO IAB box) would be sluggish and bog going up hills etc. Your secondaries when closed at lower RPM like they are from the factory will increase torque at a lower RPM thus not having a boging or sluggish feeling. Hook the secondaries up and you will notice a difference also yes the only plugs back there I do believe are the knock sensor or the black box (IAB's/Secondaries)...
Old Sep 22, 2006 | 05:46 PM
.BigSexy's Avatar
most hood white kid
Default Re: IAB Butterflies question? (ExplicitSpeed360)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExplicitSpeed360 &raquo;</TD></TR><TR><TD CLASS="quote">check out the other post thats made about the p28 ecu and h22a I have a diagram and how to on actuating the secondaries (IAB's) to the Vtec solenoid so when Vtec kicks your secondaries open.
The sluggish problem could be because your secondaries are open all the time...my car when the secondaries were wide open (not connected, NO IAB box) would be sluggish and bog going up hills etc. Your secondaries when closed at lower RPM like they are from the factory will increase torque at a lower RPM thus not having a boging or sluggish feeling. Hook the secondaries up and you will notice a difference also yes the only plugs back there I do believe are the knock sensor or the black box (IAB's/Secondaries)...</TD></TR></TABLE>
now for my next question? which models did the black box come on? and what all do I need to get?
Old Sep 22, 2006 | 06:13 PM
Banned.
I do believe the H23 had it as well so you will be looking for 92-96 Prelude SI model (H23) or SI VTEC model (H22A)
Sounds like you just need the black box and a small amount of vacuum lines...
Old Sep 23, 2006 | 10:43 AM
.BigSexy's Avatar
most hood white kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExplicitSpeed360 &raquo;</TD></TR><TR><TD CLASS="quote">I do believe the H23 had it as well so you will be looking for 92-96 Prelude SI model (H23) or SI VTEC model (H22A)
Sounds like you just need the black box and a small amount of vacuum lines...</TD></TR></TABLE>
thanks bro!!
Old Sep 23, 2006 | 11:33 AM
mgags7's Avatar
the knock is 1 pin, the IAB is 2.....
i KNOW i have a MAP connector around somewhere, but this week has been so hectic I havent been able to go get it for ya yet cory, gimme a few days, and in the meantime, pm me your address, ill send it to you early this week....
Old Sep 23, 2006 | 11:44 AM
.BigSexy's Avatar
most hood white kid
Default Re: (bb4ever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever &raquo;</TD></TR><TR><TD CLASS="quote">the knock is 1 pin, the IAB is 2.....
i KNOW i have a MAP connector around somewhere, but this week has been so hectic I havent been able to go get it for ya yet cory, gimme a few days, and in the meantime, pm me your address, ill send it to you early this week....</TD></TR></TABLE>
Thanks fot the offer matt, but I already bought a MAP connector and a knock sensor from Derek(MadCity Lude)...
it was supposed to be here today, but the plane arrived at fedex late, and it would be here until Monday, ****** bastards!!
Now I am in need of a the black box to make my IAB's work, but I am pretty sure that I dont have it...
Old Sep 23, 2006 | 11:47 AM
mgags7's Avatar
ehh i might have one of those too....lemme look first though....never know.... ludebehavi0r (marcus)might have one too laying around his basement....
Old Sep 23, 2006 | 11:55 AM
.BigSexy's Avatar
most hood white kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever &raquo;</TD></TR><TR><TD CLASS="quote">ehh i might have one of those too....lemme look first though....never know.... ludebehavi0r (marcus)might have one too laying around his basement....</TD></TR></TABLE>
let me know Matt...you'll be my hero 4ever!!!
Jesse_Boyer
12
Dec 24, 2024 02:21 AM
OgulcanTR
Sep 13, 2018 10:09 PM
CRX MASE
12
Sep 25, 2006 07:42 PM
90jdmcrxdude
Feb 19, 2006 05:45 PM
specv5150
Jun 11, 2004 02:47 PM
