Relocating battery to the trunk?
Old Sep 21, 2006 | 11:28 AM
z6EJ1's Avatar
Default Relocating battery to the trunk?
I need a how to on relocating my battery in the trunk and what are the do's and dont's.
Old Sep 21, 2006 | 11:35 AM
91slamedrex's Avatar
get a 4 gauge wire all the way down both for neg and pos and do not i repeat do not put it someware were ur car leaks water
Old Sep 21, 2006 | 11:36 AM
crxben's Avatar
Default Re: Relocating battery to the trunk? (z6EJ1)
It is really easy, all you have to do is extend your positive cable so it will reach the rear of the car. then find a good spot for your ground. buy a dry cell battery, i recommend a red top. also get a battery box. it is really easy.
Old Sep 21, 2006 | 11:47 AM
PLAGUED_DB7's Avatar
Default Re: Relocating battery to the trunk? (crxben)
I have some 6 gauge wire...will that work?
Old Sep 21, 2006 | 01:55 PM
dr_latino999's Avatar
Default Re: Relocating battery to the trunk? (PLAGUED_DB7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PLAGUED_DB7 &raquo;</TD></TR><TR><TD CLASS="quote">I have some 6 gauge wire...will that work?</TD></TR></TABLE>Too small. Minimum 4 or 2 gauge, it depends on who you talk to.
Old Sep 21, 2006 | 02:01 PM
JT2MA71's Avatar
I suggest going to a local welding supply shop and picking up some ground cable. They will have cheap cheap cheap 2ga wire.
Get a sealed battery, or use a sealed box with a vent tube.
Also, if you race, most sanctioning bodies require a battery cutoff switch on the exterior of the vehicle, clearly labeled on and off.
Old Sep 21, 2006 | 02:04 PM
Default Re: (JT2MA71)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JT2MA71 &raquo;</TD></TR><TR><TD CLASS="quote">Also, if you race, most sanctioning bodies require a battery cutoff switch on the exterior of the vehicle, clearly labeled on and off.</TD></TR></TABLE> Hence why my sedan will never be legal for any Auto-X events, I refuse to cut into my minty fresh body panels
Old Sep 21, 2006 | 02:13 PM
JT2MA71's Avatar
I replaced my taillight center section with aluminum plate framed with 3/8" bar stock...so I had no problem installing my cutoff switch back there. I tried to make it as flush as I could. I've hacked up the car enough for the cage and such, so it didn't bother me.
I'm supposed to have one in the supra...but I can't allow a hole saw to touch my supe! the body's straight and unmolested...I'd like to keep it that way!
cubnsensation
22
Feb 23, 2018 09:11 AM
JuneBugDrfter
Feb 26, 2013 11:49 AM
mojackson2390
Aug 28, 2008 10:42 AM
KooK
Jul 21, 2003 02:49 PM
Hondasaurs
Nov 22, 2002 02:29 PM
