Battery Relocation
Old Nov 20, 2002 | 11:04 AM
Hondasaurs's Avatar
Default Battery Relocation
I judt did a search and nothing showed up. I'm putting my battery in my trunk. is there anything i need to worry about like the resistance of the wire or anything like that?
Old Nov 20, 2002 | 11:12 AM
serious's Avatar
Default Re: Battery Relocation (ZC_CRX)
use low gauge wire, like 2 gauge.
unless you're got a sealed battery, you need to put the battery in a sealed case.
Old Nov 20, 2002 | 11:14 AM
Hondasaurs's Avatar
Default Re: Battery Relocation (serious)
Thanks, I got a sealed marine case for the battery.
Old Nov 20, 2002 | 11:16 AM
sackdz's Avatar
https://honda-tech.com/zerothread?id=313908
Old Nov 20, 2002 | 11:17 AM
kb58's Avatar
Banned
Or even larger (smaller number). A good place to buy it is at a welding supply shop. Should be cheaper than through a car-related shop...
Old Nov 22, 2002 | 09:40 AM
serious's Avatar
Default Re: Battery Relocation (kb58)
i've also seen people relocate the battery to where the resonator sits behind the front bumper. that way it's not in the passenger compartment, but it's also more exposed. something to think about.
Old Nov 22, 2002 | 09:59 AM
Desslok's Avatar
Some chrysler cars do that from the factory. Stratus maybe?
Old Nov 22, 2002 | 12:32 PM
keebler65's Avatar
Default Re: Battery Relocation (sp)
heh i worked for batteries plus for several years...i should remember what model car that was but i dont. probably because we turned those people away too much work to install on. anways i know that you had to turn the steering wheel all the way to one side then you could remove the access panel in the wheel well and the battery was wedged up in there.
i guess i've never looked at the specifics of that area, but it sounds kind of appealing if you can pull it off....for one, you'd keep the wire lenghts A LOT shorter, which makes the install easier and probably more effective. also, it will lower your center of gravity which will help you as long as its not too far on the edge of the car.....i guess trying it is the only sure way of knowing.
Old Nov 22, 2002 | 02:02 PM
serious's Avatar
Default Re: Battery Relocation (keebler65)
here's the picture, i saved it from another thread which i couldn't find.
sorry to whoever's car that is...
he custom welded a bracket to hold the battery in place. as far as it exploding in an accident, it seems like it would do a lot less damage exploding down there then it would in your engine compartment, though i guess the chances of it being damaged enough to explode would be greater since it's more exposed. maybe i'll do it and weld a cromoly cage around ti to protect it. blah, gotta get my swap done first....
[Modified by serious, 6:03 PM 11/22/2002]
Old Nov 22, 2002 | 02:29 PM
BROOD's Avatar
Try to find a good quality 1 gauge or 2 gauge cable with multistrand conductor. The multistrand contruction helps make the wire more flexable and thus easier to route through your car. Sometimes welding cables are alittle too stiff to route easily. Good cable will not give you resistance problems......you can measure the ohms before installing as well.
Some other tips that may help:
Ground the battery to the chassis really well. I double grounded it in the rear hatch and used a 4 gauge cable to run ground to the front original location. Overkill...Yes but no chances of a faulty ground with that.
The extra fuse or circuit breaker is very important. Yes there is a fuse under the hood for the engine bay but it won't protect the cable from the engine bay back to the trunk. You will need an additional fuse/breaker in the positive cable within 12-14" of the battery.
An if you plan to make trips to the drag track you might as well start thinking about the battery kill switch that they will require. Remember that it needs to cut battery power as well as the alternator power.
And bolt that thing down good too. Tech rules will require it but it would also suck to have a 30lb battery chucked at the back of your head during a crash
Good luck
[Modified by SLPR, 3:31 PM 11/22/2002]
civics4lyfe
Jan 23, 2009 03:19 PM
5150CIVIC
Audio / Security / Video
10
Mar 25, 2008 06:46 AM
boosted civic 2k6
Dec 4, 2005 01:30 PM
hahahahhah
25
May 25, 2004 05:11 PM
