Car Not Starting Up!! HELP!
Old Sep 21, 2006 | 05:27 AM
fitchboy22's Avatar
Default Car Not Starting Up!! HELP!
Ok so heres the dilly. I got a 1993 honda civic DX 2 door. It is not starting up. It rotates but wont fire up. It just turned off while i was at a red light. So I thought initially at first it was the main relay cause as we all know, main relays are always the first concern most of the time when it involves heat. But in this case, the main relay checked out fine. I did a test. Timing belt is fine. The motor is gettin gas cause I smell gas when I try to crank it up. All fuses check out okay. I tried spraying starting fluid in the intake..still doesnt work. Anyone give me something to check...or hae you had a similar problem? Let me know! Thanks.
Daniel
Old Sep 21, 2006 | 06:53 AM
stock_honda_coupe's Avatar
Default Re: Car Not Starting Up!! HELP! (fitchboy22)
Its probably your coil, There as bad as the main relays for just going with no warning. It happened on my car.
Old Sep 21, 2006 | 10:40 AM
lthao61's Avatar
Default Re: Car Not Starting Up!! HELP! (stock_honda_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock_honda_coupe &raquo;</TD></TR><TR><TD CLASS="quote">Its probably your coil, There as bad as the main relays for just going with no warning. It happened on my car.</TD></TR></TABLE>
what he said
nismogrendel
Apr 24, 2010 01:43 AM
VLP
Nov 14, 2007 03:06 PM
2Point2EH2
Aug 24, 2006 10:26 PM
CRX_Control
Aug 25, 2005 06:57 AM
wilrock
Oct 18, 2004 08:44 PM
