for Steering wheel owners and had ot take out the cabel reel
Old Sep 20, 2006 | 06:31 PM
es_squared's Avatar
Default for Steering wheel owners and had ot take out the cabel reel
I got a wheel, NRG quikrelease, and NRG short hub. if anyone has the same setup you have to take out the cable reel which means, no horn. question is how did you hook the horn back up?
Old Sep 20, 2006 | 06:35 PM
bb_one's Avatar
Default Re: for Steering wheel owners and had ot take out the cabel reel (es_squared)
When you unplug the cable reel you can make leads to connect to the NRG hub to the plug that was connecting to the cable reel (horn, SRS). You just need the pin diagram.
Old Sep 20, 2006 | 06:50 PM
crdcz03's Avatar
Fortune Cookie Member
heres a write up i did a few months ago
http://www.superhonda.com/foru...+horn
be wary tho, the wire that goes from the hub to the horn contact ripped out of mine and my horn currently doesnt work.
which brings me to a question... is that white disk (the horn contact) attached to your hub or not? b/c the only way i can see to fix the problem of the wire ripping itself out is by attaching the contact to the hub but i cant remember if it was like that to begin with or not...
Old Sep 20, 2006 | 07:33 PM
es_squared's Avatar
Default Re: (crdcz03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crdcz03 &raquo;</TD></TR><TR><TD CLASS="quote">
which brings me to a question... is that white disk (the horn contact) attached to your hub or not? b/c the only way i can see to fix the problem of the wire ripping itself out is by attaching the contact to the hub but i cant remember if it was like that to begin with or not... </TD></TR></TABLE>
ok thanks for the replys guys. ok i see.. im not good with wiring **** so ill probly need help. yoru DIY helps alot tho man
the white disk? thats the other half of the quik release.
Old Sep 21, 2006 | 07:16 PM
crdcz03's Avatar
Default Re: (es_squared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by es_squared &raquo;</TD></TR><TR><TD CLASS="quote">
the white disk? thats the other half of the quik release. </TD></TR></TABLE>
the white disk should have come with the short hub. i just want to know if yours is attached to your hub or is the wire from the disk the only thing holding it to the hub.
Old Sep 21, 2006 | 09:11 PM
mgags7's Avatar
if it helps the horn wire is all the way on the side, either all the way left or right, i forget now....
ge_ej1
10
Nov 8, 2007 07:25 AM
Mr.Fairlady
Feb 25, 2004 11:19 PM
BlazingSIRT
May 8, 2003 05:17 AM
poison
May 13, 2002 10:23 PM
