95 civic VX cracked manifold :( solution inside please discuss
Old Sep 20, 2006 | 04:58 PM
bluebird's Avatar
Default 95 civic VX cracked manifold :( solution inside please discuss
well my stock manifold has cracked and I am very angry. So my solution is as follows. I plan on using a dx manifold along with the cat. My question is has anyone done this? Any adverse effects on it? I know I am going to have to extend my o2 sensor harness ( no big deal). But will it affect mpg ? I dont see why but just checking before I make a mess. Thanks
Old Sep 20, 2006 | 05:00 PM
Luserkid's Avatar
Default Re: 95 civic VX cracked manifold :( solution inside please discuss (bluebird)
How bad of a crack? Cant you just run a quick bead over it to hold it for a while.
I dont think youll feel any downgrade to the dx manifold maybe a little more back pressure but nothing that will hurt you (unless you have a clogged cat.)
Old Sep 20, 2006 | 05:03 PM
bluebird's Avatar
Default Re: 95 civic VX cracked manifold :( solution inside please discuss (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">How bad of a crack? Cant you just run a quick bead over it to hold it for a while.
I dont think youll feel any downgrade to the dx manifold maybe a little more back pressure but nothing that will hurt you (unless you have a clogged cat.) </TD></TR></TABLE>
Well I recently did a smog check and the cat is almost done... So instead of trying to replace that utterly expensive cat I thought it would be easier to go with the bottom bolted cat and purchase one of those. Considerably cheaper and I have never had any cracking issues with those manifolds before... As for welding it . Sure it could be welded but I dont think that cat is very good anymore.
Old Sep 20, 2006 | 05:47 PM
Targa250R's Avatar
be professional
Better check with a smog ref beforehand to make sure it is CA-legal to swap out the close-coupled cat.
Old Sep 20, 2006 | 09:16 PM
bluebird's Avatar
Default Re: 95 civic VX cracked manifold :( solution inside please discuss (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">Better check with a smog ref beforehand to make sure it is CA-legal to swap out the close-coupled cat.</TD></TR></TABLE>
Thats true also...
Old Sep 21, 2006 | 07:24 AM
bluebird's Avatar
any other insight?
Old Sep 21, 2006 | 07:53 AM
spooncivic1's Avatar
put a DX or EX/Si header on it, and a DX or EX/Si Cat.
Old Sep 21, 2006 | 09:36 AM
zacatkings's Avatar
Default Re: (spooncivic1)
what where you doing? to much nitrous?
Old Sep 21, 2006 | 10:31 AM
bluebird's Avatar
Default Re: (zacatkings)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zacatkings &raquo;</TD></TR><TR><TD CLASS="quote">
what where you doing? to much nitrous? </TD></TR></TABLE>
LOL...NO. I was checking everything and noticed an exhaust leak
Old Sep 21, 2006 | 10:40 AM
Relic1's Avatar
the location of the O2 sensor may cause issues. The P07 is setup so it's expecting the O2 to sit close to the engine, further away and you'll run richer which may be enough to cause problems.
I have a VX exhaust mani sitting here if you need one that isn't cracked.
Old Sep 21, 2006 | 03:08 PM
xbabysharkx's Avatar
the ex manifold wont pass visual. i have an hx and had to bite the bullet. $180
Old Sep 21, 2006 | 05:41 PM
bluebird's Avatar
Default Re: 95 civic VX cracked manifold :( solution inside please discuss (xbabysharkx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xbabysharkx &raquo;</TD></TR><TR><TD CLASS="quote">the ex manifold wont pass visual. i have an hx and had to bite the bullet. $180 </TD></TR></TABLE>
thats without the cat though.... I may need a cat soon
crz650
Mar 16, 2019 01:52 PM
6footmidget
22
Jun 1, 2011 12:28 PM
jrm
Honda Civic (2001 - 2005)
Feb 1, 2010 04:50 PM
the.hamburglar
Mar 9, 2006 10:06 AM
Type-X
Feb 14, 2005 12:13 PM
