do these manifolds have a good flow design?
Re: do these manifolds have a good flow design? (the.hamburglar)
It has a turbonetics stamp on it, so look it up under turbonetics. If you really want a log manifold, then get one from http://www.cc-fab.net or some place that has logs mani's that are not cast, they cost around the same. Also they should flow a little better than cast. Personally I would save your money and get a equal length or chuck norris
Re: (Sketch_hs)
nothing wrong with cast iron manifold...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs »</TD></TR><TR><TD CLASS="quote">quick spool </TD></TR></TABLE>
werd to that....
cast manifold more of a fixed design, while custom welded together log manifold varies in designs and downpipe placement
werd to that....
* B A N N E D *
1 Post
Check spoolin, LSD motorsports.... Youll probably save some money AND get a better mani... LSD makes a MINI tubular that s really cool... I own one rock it and love it... Flows better than log, AC and PS compat.
They are a sponsor here.
in my oppinion, if you are buying that thing new for over 300 you could do better.
Re: do these manifolds have a good flow design? (bigdaddyvtec)
ok now that we are on the topic. i kinda see what you mean now by the poor flow. the 1 and 4 runners are completely facing each other which brings down the exhaust gas velocity right? whats a good manifold to get for around the $300 mark?
* B A N N E D *
1 Post
Contact Mike at LSD motorsports and tell him Spiker sent you his way...The mini tubular is a great option for you!!!
https://honda-tech.com/zerothread?id=1336590
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar »</TD></TR><TR><TD CLASS="quote">ok now that we are on the topic. i kinda see what you mean now by the poor flow. the 1 and 4 runners are completely facing each other which brings down the exhaust gas velocity right? whats a good manifold to get for around the $300 mark? </TD></TR></TABLE>
http://www.shop.cc-fab.net/dis...yId=1
also can anyone get a part number for this manifold. im thinking about buying one</TD></TR></TABLE>
no problem you can use my image ;-)
contact turbonetics....they can tell you exactly what it is.
Re: do these manifolds have a good flow design? (mike93boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93boost »</TD></TR><TR><TD CLASS="quote">
http://www.shop.cc-fab.net/dis...yId=1</TD></TR></TABLE>
yeah, just got mine this past weekend best manifold for the money imo.
Re: do these manifolds have a good flow design? (erebunicrx)
was that your image? sorry man, i should have asked. i just saved it a while back on my computer because i liked that manifold. that was when i knew nothing about them
thats looks like the symbol on some stuff ive seen coming off ebay, its a turbonetics LOOK-A-LIKE symbol to fool you. i may be on crack though
Re: do these manifolds have a good flow design? (SPOOLINmatt)
the Turbonetics symbol?? dunno if theres knock-offs of that. hahaha, but that image is one i took of a REAL turbonetics manifold
476 whp / 323 tq @ 17 PSI
Re: do these manifolds have a good flow design? (jarel)
the design of a log manifold will spool much quicker but the ramhorn manifold has a stronger top end.
if you pick up a log manifold, i recommend spoolinperformance
get the ramhorn, http://www.rld-fab.com/
spoonsports12
10-12-2005 09:53 AM
