z6 or y8?
Old Sep 20, 2006 | 03:31 PM
puertoroc7976's Avatar
Default z6 or y8?
which is stronger
Old Sep 20, 2006 | 03:35 PM
knockout's Avatar
Default Re: z6 or y8? (puertoroc7976)
z6 block + y8 trans + y8 head + z6 cams.
the y8 oiling system is oil consuming.
the z6's tranny doesnt have steel shift forks like the y8's tranny has.
the y8 head flows slightly more.
the z6 cams are slightly more aggressive.
correct me if im wrong.
they both have their strong and weak points. but either is fine if you are going OBD1.
Old Sep 20, 2006 | 03:40 PM
Default Re: z6 or y8? (knockout)
THX HIT THAT RIGHT ON THE SPOT
Old Sep 20, 2006 | 03:53 PM
t0p_sh0tta's Avatar
^ True for the most part. IIRC the Z6 head will flow better. Just swap the Y8 intake manifold.
What are you doing with the motor?
Old Sep 20, 2006 | 03:56 PM
tsdenny's Avatar
Default Re: z6 or y8? (t0p_sh0tta)
i think the d15b vtec cam will be better
Old Sep 20, 2006 | 03:57 PM
t0p_sh0tta's Avatar
Default Re: z6 or y8? (void_accord)
If you're even going to bother swapping out the cam, go with aftermarket.
Old Sep 20, 2006 | 04:07 PM
rclark's Avatar
the Y8 head is pented... better for boost, if that matters
Old Sep 20, 2006 | 11:00 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knockout &raquo;</TD></TR><TR><TD CLASS="quote">the z6's tranny doesnt have steel shift forks like the y8's tranny has.</TD></TR></TABLE>
This is a non-issue. Neither transmission is "better." The aluminum forks break, and the steel forks bend - both issues will cause major problems. You generally want to just look for a low-mileage transmission in good condition with no grinds, regardless of whether it is a Z6 or a Y8 transmission.
Old Sep 21, 2006 | 08:14 AM
gottalovethe4door's Avatar
this could go on forever...
they both have their little pros n cons ... it realy ends up being a toss up/ prefference decison
blackhope121
Jul 2, 2007 11:37 AM
Syndacate
18
Apr 24, 2006 06:55 PM
TehMoonRulz
May 30, 2005 08:51 AM
rasinhell
16
Jan 14, 2005 08:05 AM
Dasavior
May 4, 2004 07:41 AM
