LC1 wiring into turbo DA...odb1
Old Sep 20, 2006 | 05:55 AM
ichbinsobose's Avatar
Default LC1 wiring into turbo DA...odb1
I looked at all the ecu pinouts, and my wire colors DO NOT match Whatever, i got most of it done I think.
I have one question still though.... where the expletive does the analog1 (which I intend to use with crome) go? D14 says everyone...should be red/white. Its not. It's green/orange and reads ~.2 - .5 V when I turn the car on. Questionable.
When I wire it in with either the green/orange wire, or the only red/white wire in my ecu plugs, the lc1 does the heat up mode blink correctly...and then throws error code 4.
4..4...4....4....4....4....44...4.4.4.4.4.4.4..4.4 aaaagggggggggggh
Cant figure this sucker out, any help?
Old Sep 21, 2006 | 10:46 AM
Default Re: LC1 wiring into turbo DA...odb1 (ichbinsobose)
Old Oct 27, 2007 | 05:44 AM
laziebun's Avatar
http://www.tleone.com/index.ph...d=104
try that it has all the colors and pin outs....good luck
ichbinsobose
Sep 20, 2006 05:52 AM
BlueShadow
Jun 20, 2005 03:24 PM
raceACCORDingly
Jan 7, 2003 05:31 PM
