vtec question
Old Sep 19, 2006 | 05:13 PM
perseverance's Avatar
Default is my motor vtec?
ok, i have a 97 ex coupe. I heard the motor is supposed to be vtec but on the valve cover it doesn't say vtec. I've worked on a lot of other cars at my job where the valve covers say vtec. thx for the help in adv.
Old Sep 19, 2006 | 05:19 PM
nsxmatt's Avatar
Default Re: is my motor vtec? (perseverance)
It's vtec.
Old Sep 19, 2006 | 05:28 PM
knockout's Avatar
just because it doesnt say vtec doesnt mean anything.
if it has the stock motor (or maybe a different d16y8) then it is vtec.
Old Sep 19, 2006 | 05:40 PM
thx a lot... i wasn't sure although i think i seen the vtec solenoid. thx
Old Sep 20, 2006 | 02:26 AM
uLikeMyPreludeSi's Avatar
it should be. maybe if you run it hard with the windows down you can maybe hear it, but for sure your not going to feel it.
Old Sep 20, 2006 | 03:09 AM
teamvirus's Avatar
My car breaks a lot!
Default Re: is my motor vtec? (uLikeMyPreludeSi)
check the spark plug location, ive noticed that vtec heads have them closer to the front where non-vtec are on the fire wall side
Old Sep 20, 2006 | 03:34 AM
yeah... i definately don't feel the vtec. that's why i asked if it was vtec. i was hoping it wasn't and it would explain my lack of speed. I've never been in a car this slow before. Makes me wanna do a swap immediately.
Old Sep 20, 2006 | 06:25 AM
CivicDude2k4's Avatar
Yeah you won't feel it, if you have an exhaust or anything you can probably hear the tone change when VTEC engages. It only has an effect on the lift of the intake cams on SOHC motors, the exhaust cams never vary. so you never really get the full effect like you would in a DOHC
Old Sep 20, 2006 | 06:28 AM
jays93eg6's Avatar
Default Re: is my motor vtec? (CivicDude2k4)
I am not real sure on the Y8 head, but it should have the Vtec solenoid on the back left side of the head.
Old Sep 20, 2006 | 06:37 AM
Egezzy's Avatar
Spongebrad Squarepants
Default Re: is my motor vtec? (jays93eg6)
look for the vtec soleniod best way to check
Old Sep 20, 2006 | 07:01 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: is my motor vtec? (Egezzy)
look for one of these bad boys
Old Sep 20, 2006 | 07:04 AM
Kruzen510's Avatar
Default Re: is my motor vtec? (SkoundrelUSA)
Should be vtec unless someone changed the motor. My Si's valve cover didn't say vtec but it was a z6.
Old Sep 20, 2006 | 07:08 AM
LowSlow93Sol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">look for one of these bad boys
Yep. thats it.
Old Sep 20, 2006 | 09:26 AM
WestDC5's Avatar
You don't need the valve to say vtec to actually have vtec
Old Sep 20, 2006 | 09:33 AM
your_moms_fat_ass's Avatar
Default Re: is my motor vtec? (WestDC5)
agreed... sohc vtec blows, the only way i can feel it in my cousins car (he has a 2000 civic ex), is to put the thing from drive4 down to drive2, and then hover the rpms just below 5500, the vtec engaging point, and then suddenly floor it, you can BARELY tell anything, but you can a little, if he had a short ram intake or cold air, then you could tell it because it would get louder, but hardly no pull at all. My dohc b16a pulls like a bitch, fuel pressure is bumped up to 50 psi... don't ask why its the only way it runs good, it needs to be tuned really bad, cold air intake
Old Sep 20, 2006 | 09:39 AM
turbociviccoupe's Avatar
Default Re: is my motor vtec? (your_moms_fat_ass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by your_moms_fat_ass &raquo;</TD></TR><TR><TD CLASS="quote">agreed... sohc vtec blows, the only way i can feel it in my cousins car (he has a 2000 civic ex), is to put the thing from drive4 down to drive2, and then hover the rpms just below 5500, the vtec engaging point, and then suddenly floor it, you can BARELY tell anything, but you can a little, if he had a short ram intake or cold air, then you could tell it because it would get louder, but hardly no pull at all. My dohc b16a pulls like a bitch, fuel pressure is bumped up to 50 psi... don't ask why its the only way it runs good, it needs to be tuned really bad, cold air intake </TD></TR></TABLE>
come on....its a freaking sohc...and an auto...just drive it
Old Sep 20, 2006 | 09:46 AM
eetmaishiet's Avatar
Default Re: is my motor vtec? (turbociviccoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perseverance &raquo;</TD></TR><TR><TD CLASS="quote">yeah... i definately don't feel the vtec. that's why i asked if it was vtec. i was hoping it wasn't and it would explain my lack of speed. I've never been in a car this slow before. Makes me wanna do a swap immediately. </TD></TR></TABLE>
SOHC VTEC engines aren't as loud compared to the B-series engines and you don't really feel the "kick" either. You can boost the motor and put out more power than a stock B-series .
Old Sep 20, 2006 | 10:04 AM
WillyLopez
Guest
Posts: n/a
It's vtec.
Old Sep 21, 2006 | 07:05 AM
55greenEK's Avatar
all i have on my 98 is injen exhaust would i hear it louder if i get my intake on.
Stevemyster
May 16, 2011 12:45 PM
asphalt788
Aug 29, 2008 10:24 PM
honda97civic
18
Dec 4, 2007 06:12 PM
ZiggyDSL
Mar 20, 2003 06:33 PM
TeamHATCH
Nov 22, 2002 04:41 PM
