CIVIC CLUSTER HELP
Old Sep 19, 2006 | 04:43 PM
JDM manc 10's Avatar
Default CIVIC CLUSTER HELP
Hey ppl,
i have a honda civic dx and the cluster has no tach. i just bought a new cluster from the ex with a tach. i thought i was going to be able to plug and play but i noticed that there is an extra harness that i could connect (im guessing cause thats the one for the tach). does anyone what i could connect those extra wires too?
thanks a lot
Old Sep 19, 2006 | 04:51 PM
BlueIntegraBoy's Avatar
Default Re: CIVIC CLUSTER HELP (JDM manc 10)
Just plug in the two main clips and the SRS (yellow) and you'll be fine.
It works, trust me. The tach wire is already prewired in the harness.
Old Sep 19, 2006 | 05:19 PM
SkorchedAsh's Avatar
omg, i soo need to have that then too. But is there a way i can get a JDM cluster with mph included? Or would i need a EDM?
Old Sep 19, 2006 | 05:35 PM
Default Re: (SkorchedAsh)
Why do you need a JDM cluster with MPH? Why not just stick with a USDM?
Old Sep 19, 2006 | 06:30 PM
hey thanks for the help.... now i have seem to have another problem.... i put in the cluster and i turned on the car, but as soon as i turn it on... it turns off.
i have no idea why, and i doubt that it has to do anything with the cluster.
any ideas?
Old Sep 19, 2006 | 06:32 PM
Default Re: (JDM manc 10)
More details please
Old Sep 19, 2006 | 07:02 PM
Default Re: (BlueIntegraBoy)
i turn on the car and if i dont give it gas it turns off, if i give it gas it stays on until i let off once it gets below idle. my car isnt idling im guessing.
anyone know whats up?
Old Sep 19, 2006 | 07:09 PM
It's your engine, not the cluster.
Old Sep 19, 2006 | 07:13 PM
wheelmanbg's Avatar
your car shuts off or just the tach goes to zero?
Old Sep 19, 2006 | 07:14 PM
i doubt its the engine, cause then wouldnt my car not turn on at all?
i think its the idle.
Old Sep 19, 2006 | 07:21 PM
the car turns off.
Old Sep 19, 2006 | 08:14 PM
wheelmanbg's Avatar
so yuor car won't run unless you step on the gas?
I don't see how that would have anything to do with the cluster...
Did it just start doing it when you changed the cluster?
Old Sep 20, 2006 | 07:19 AM
Default Re: (wheelmanbg)
well the car is at home because it isnt registered yet, so i didnt even turn on the car befre i changed the cluster to see if that was it.
thats why im doubting its the cluster.
but i dont get it.... whats wrong w/ this?
Old Sep 20, 2006 | 08:53 AM
Malakai's Avatar
so swap it back just to make sure then go from there.
Old Sep 20, 2006 | 10:12 AM
wheelmanbg's Avatar
Default Re: (Malakai)
how long has it been just sitting?
you might have bad gas if it's been a while
Also check your distributor cap to make sure it's clean
Old Sep 20, 2006 | 11:14 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Why do you need a JDM cluster with MPH? Why not just stick with a USDM?</TD></TR></TABLE> White Faced Guages
hondan00b95
Honda Civic (2001 - 2005)
Dec 7, 2014 10:27 PM
V.MoMO
Sep 12, 2010 08:44 AM
Frito-Ray
Feb 15, 2005 12:12 AM
sparq
Jan 18, 2003 03:13 PM
67wayz
Jul 25, 2002 11:26 AM
