higher performance camshaft?
Soon, im getting the valves adjusted and wondered if this is the time to put in some performance camshafts/ what kind? And if so will the specs need to be different on the valve gapping. Im basically looking for a good drop/or bolt on camshaft.
well i would still advise tuning, but most stage one cams don't require you to upgrade your valvetrain........but then again if you have higher goals for you car there is no sense in buying a part twice.....save your money
89 CRX SI
Apr 13, 2003 12:58 PM
