EG CX with Si Cluster - Tach Reading is way off - inaccurate
Old Sep 18, 2006 | 02:12 PM
ham's Avatar
ham
Default EG CX with Si Cluster - Tach Reading is way off - inaccurate
I have a CX with an Si tach and the tach is way off. I mean its reading 4500 rpm when Im hitting redline. Its about 30% off the whole range. Is there any way to adjust it or am i screwed>?
Old Sep 18, 2006 | 04:10 PM
ham's Avatar
ham
Default Re: EG CX with Si Cluster - Tach Reading is way off - inaccurate (ham)
meh
Old Sep 18, 2006 | 06:21 PM
spooncivic1's Avatar
try to pry the needle back some, mine used to do this aswell, until i took a flathead and pryed it away from the face a little bit.
Old Sep 19, 2006 | 07:51 AM
ham's Avatar
ham
Default Re: (spooncivic1)
i have no idea what that would do, except bent or break the needle. are you sure it worked?
Old Sep 19, 2006 | 08:04 AM
it might be where the needle is pressed against the face too much
or someone might have taken the needle off prior to you having it, and installed it incorrectly
Old Sep 20, 2006 | 03:43 AM
ham's Avatar
ham
anybody else?
flatblack-h22
May 22, 2014 05:30 PM
PaddingtonBear
Apr 7, 2010 05:33 PM
WhiteOnRice
Aug 12, 2006 12:02 PM
GCOAP
Jul 3, 2005 08:39 PM
94blackhatch
Feb 14, 2004 07:24 AM
