obd1 to obd2 distributor wiring ,please help!!
Old Sep 18, 2006 | 09:47 AM
turbo77nyc's Avatar
Default obd1 to obd2 distributor wiring ,please help!!
Im tring to wire in a prelude obd1 distributor into my 99 prelude.I wanted to try to change the distributor to obd1 couse when I went to a p28 ecu it started throwing code 22 and the car runs like ****.I know everyone says obd2 distributor works with the p28 but I tried everything and its still happening.Can anyone help?I gotta get this car on the road and I have very little time to troubleshoot(thanx to my 3 month old son).
Ive been into this car thing for a few years but im getting to a point where I have very limited time and money,your help will be much appriciated,thanx.
Old Sep 18, 2006 | 10:06 AM
PrecisionH23a's Avatar
Default Re: obd1 to obd2 distributor wiring ,please help!! (turbo77nyc)
You have to convert the CKP and CYP sensors to the obd1 dizzy.
Stay obd2 dizzy and run the ecu conversion harness if you want to run an obd1 p28 ecu.
Old Sep 18, 2006 | 10:38 AM
A Blue Lude's Avatar
Default Re: obd1 to obd2 distributor wiring ,please help!! (PrecisionH23a)
I have run into a bunch of people locally that say you need to convert to an OBD1 distributior to run an OBD1 ECU and Crome (obviously with a conversion harness as well).
My car did both Hondata and Crome just fine though, so it has left me confused about the whole thing.
Old Sep 18, 2006 | 10:43 AM
Default Re: obd1 to obd2 distributor wiring ,please help!! (A Blue Lude)
You do not need an obd2 distributor to run an obd1 ecu. You simply need the obd2-obd1 conversion harness for the ecu. End of story. Whoever supplied you with your information is wrong.
Old Sep 18, 2006 | 01:18 PM
turbo77nyc's Avatar
Can I match the wires on the obd1 dizzy to the wires that plug into the obd2 distributor?Olso how do the wires on from the ckp and cyp sensors wire into the distributor?
Old Sep 18, 2006 | 05:58 PM
turbo77nyc's Avatar
I cant find anything on the web as far as wiring the obd1 prelude dizzy,im tring to identify the wires so I could wire it into the existing harness
the wires are as following(FIRST PLUG):
green
green/yellow
blue
blue/yellow
blue/white
yellow/blue
white
yellow
SECOND PLUG:
blue
yellow/black
Old Sep 19, 2006 | 09:17 PM
XRSLUDE's Avatar
I'm trying to do the same with my distributor...Ialso is looking for a write up in doing the convertion...the obd2 dizzy has six wires on the plug and the obd1 has eight wires...jus wondering if I can use the plug on the obd2 dizzy on to the obd1 dizzy...but their will be two extra wires... Those two extra wires ...do they go to the crank sensor...lmk! anyone
Old Sep 21, 2006 | 03:17 AM
XRSLUDE's Avatar
Default Re: obd1 to obd2 distributor wiring ,please help!! (XRSLUDE)
Anyone have any ideas on the wiring...Thanks!
Old Sep 21, 2006 | 03:20 AM
XRSLUDE's Avatar
ooops! I mean that the obd2 dizzy first plugs has four wires not six...
Old Sep 22, 2006 | 04:49 AM
turbo77nyc's Avatar
Those extra 4 wires are for the cyp and ckp sencors from the crank I ordered the manual for the 92-95 prelude to get the diagram for the obd1 dizzy plug I will let you know when I get it
PS:I didn't find anything on line about the prelude obd1 dizzy
Old Sep 22, 2006 | 05:20 AM
XRSLUDE's Avatar
THANKS! LMK...When you find something out...I to can't find anything on line...
jdmjin
Nov 26, 2017 08:59 PM
dfanatic86
Mar 5, 2014 05:23 AM
BoltonGSR
Jun 13, 2008 08:49 PM
Adam West
May 8, 2006 03:47 AM
revlimitcrx
Apr 2, 2006 12:29 PM
