radiator
Old Apr 30, 2002 | 07:32 AM
Dorikamu's Avatar
Default radiator
I have heard most pple recommend a del sol vtec radiator with the swap.
I am just curious, do pple mean the USDM del sol radiator.. that would be the SOHC del sol, rite? so any del-sol radiator is fine? I suppose, I just dont wanna get the wrong parts.
thanks
Old Apr 30, 2002 | 07:52 AM
B_CRUZ!'s Avatar
Default Re: radiator (chusai)
i think people mean the stock DOHC vtec del sol... i heard it was the same as the automatic 5th gen civics.
Old Apr 30, 2002 | 08:42 AM
Dorikamu's Avatar
Default Re: radiator (B_Cruz)
so is it USDM del sol, or JDM del sol?
Old Apr 30, 2002 | 08:43 AM
JeffS's Avatar
This is correct... both parts. It's the same width, is thicker, and drops right in with no additional work necessary.
Old Apr 30, 2002 | 08:44 AM
JeffS's Avatar
U.S.
Old Apr 30, 2002 | 10:54 AM
Dorikamu's Avatar
Default Re: radiator (JeffS)
so auto EG has bigger radiator than manual EG?
Old Apr 30, 2002 | 11:44 AM
JD_B18CDX's Avatar
What you need is the the Del sol DOHC vtec. Its a dual core radiator so theoretically has twice the cooling capability as the stock ones.
The stock 5G civic automatic and manual only have a single core radiator. You will have to trust me on this because I have them.
The delsol makes 160HP so its logical that it MIGHT be enough to cool a 170HP GSR or a 200HP ITR.
The stock radiator will work but MIGHT overheat if you try to sustain WOT for long period of time.
Old Apr 30, 2002 | 01:49 PM
Dorikamu's Avatar
Default Re: radiator (johnd)
so it's the radiator from JDM Del Sol that I should be using.
since the USDM del sol is SOHC and 125hp.
how much will a JDM del sol radiator cost?
Old Apr 30, 2002 | 02:09 PM
JeffS's Avatar
#1) You need to study up on your Del Sol trivia...
#2) As was said earlier in this thread... DOHC VTEC Del Sol. - it doesn't matter which frickin' market it's from... it was sold in both.
#3) If you're not going to read for an answer, or at least verify whether what someone says is correct, then don't bother asking.
#4) yes, I am...
Old Apr 30, 2002 | 02:10 PM
markpaco's Avatar
No. While you can use one from a JDM Honda Civic CR-X SiR, it is the same as a USDM Civic Del Sol VTEC. From reading your posts, it seems as if you don't know that there is such thing as a B16A-equipped Del Sol. Well, there is. It was offered from 94-97. So just get a USDM dual core Honda Civic Del Sol VTEC radiator. That is the official name of the model. You are confusing the Honda Civic Del Sol Si which is pretty much a Honda Civic Si/EX with the D16Z6 SOHC.
Old Apr 30, 2002 | 04:21 PM
Dorikamu's Avatar
chill out dude.. while I appreciate pple's answers.. it was confusing that I didnt know DOHC del sol is sold in both market. So now that it's clear, I fully understand it...
and if you are so annoyed, dont bother to post. I dont need your attitude. and yes, I dont know enuf about Del Sol, that's why I asked. if you have a problem, **** off
Old Apr 30, 2002 | 04:22 PM
Dorikamu's Avatar
Default Re: radiator (markpaco)
thanks, it become clear to me now
Old Apr 30, 2002 | 05:32 PM
alphapark1's Avatar
use the stock radiator. alot of people use the stock one with no problems.
I did a gsr->into a del sol that was originally sohc 1.5
i go no radiator problems and I had the car for almost a year like this.
Old Apr 30, 2002 | 10:32 PM
J_SpeC_EK's Avatar
http://www.radiator.com
brand new DOHC del sol radiators for 129.. thought i would share..
seoul-child
Sep 7, 2006 11:06 AM
the soL that could
12
Mar 25, 2006 03:58 AM
egciviccx
Mar 28, 2003 11:37 AM
whagkangmakulet
Mar 19, 2002 09:04 PM
