engine shut off at light!
Old Sep 16, 2006 | 05:13 AM
wifesaynogo's Avatar
Default engine shut off at light!
so i was at a light last night and the car had been runnig fine. No impending warning of trouble or anything and then in the blink of an eye the oil light and cel come on at the same time and the car shuts off immediately. I got the car pushed to the side. I checked the dip stick and the oil is low but when i go to turn the car on the fuel pump wont prime. I usually hear it very well. So i took the backseat out to make sure I could hear it and nothing. The car cranks over like a champ but doesnt start. any suggestions?
Old Sep 16, 2006 | 06:10 AM
Default Re: engine shut off at light! (wifesaynogo)
I swear I cant find the lil grey plug to jump the ecu to get the code for the cel....theres only so much space to look for it under there
Old Sep 16, 2006 | 07:44 AM
JDMFantasy2k's Avatar
well obviously you're not getting fuel. Chances are there isn't a code. I'd begin by checking fuses obviosly and then checking the PGM-FI main relay. After that i'd check to make sure the pcm has powe and ground and is functioning properly. Then test the fuel pump, and it's wiring and go from there.
Old Sep 16, 2006 | 08:10 AM
HNP's Avatar
HNP
Default Re: engine shut off at light! (JDMFantasy2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFantasy2k &raquo;</TD></TR><TR><TD CLASS="quote">well obviously you're not getting fuel. Chances are there isn't a code. I'd begin by checking fuses obviosly and then checking the PGM-FI main relay. After that i'd check to make sure the pcm has powe and ground and is functioning properly. Then test the fuel pump, and it's wiring and go from there. </TD></TR></TABLE>
what he said...
Old Sep 17, 2006 | 06:23 AM
Default Re: engine shut off at light! (HNP)
yea i fixed it right after i made the second post. one of the wires shorted and blew the acg fuse next to the srs...simple prob...thanx though
Old Sep 17, 2006 | 06:34 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Find the source of the short, so it doesn't happen again!
Old Sep 18, 2006 | 05:42 AM
Default Re: engine shut off at light! (JDM_Ej)
oh yeah i found the short to i just didnt state it. one of the terminals on my fuel cut off switch came loose and touched the chassis shorting the fuse...its all taken care of
bert428scj
Jul 26, 2016 12:58 PM
billy hoang
12
Apr 11, 2009 07:54 AM
nemeii
23
Aug 10, 2008 03:10 PM
jay-tec
Oct 26, 2007 08:24 AM
01IntegraSE
Mar 20, 2003 05:56 PM
