Speedo stopped working, alternator bad?
Old Sep 14, 2006 | 03:33 PM
wakeboard_dude5's Avatar
Default Speedo stopped working, alternator bad?
alright to start off with the car is a 96 hatch with GSR swap. The fuse under the dash for the speedo/alternator keeps blowing out and also throwing a cel for electrical load dectector. I've retraced all possable wires to find a short but havn't found anything. The weird thing is the fuse doesn't blow right away, it usually takes a drive around the block to make it go. Also, it seems to go when the engine is just ideling while coasting. Has anyone have this happen? Could it possably be the alternator? Or would you surgest to replace the underhood fuse box where the ELD is?
Old Sep 14, 2006 | 03:47 PM
JDM-EJ1's Avatar
Default Re: Speedo stopped working, alternator bad? (wakeboard_dude5)
How does your VSS look? I'm not an expert on this, but I would think a speedometer and an alternator would be on the opposite ends of the spectrum.
Old Sep 14, 2006 | 11:44 PM
Yeah leave it to honda to have those two share a fuse. Tomorrow i'll be picking up more fuse's and dissconnect things to see what won't make it blow. But i would still REALLY appreciate any help with this one, this one problem may decide if i stay with honda's or take a loss and try something else
Old Sep 15, 2006 | 07:16 AM
ITR97-143's Avatar
Default Re: (wakeboard_dude5)
you might want to have your alt tested to make sure it is charging no more then 14.5v on the high side. ive seen some alts with bad reg's charge as high as 18v and fry wiring.
Old Sep 15, 2006 | 08:30 AM
kidderoner's Avatar
the alternator has nuthing to do with that.
Old Sep 15, 2006 | 10:07 AM
reason being? it's very logical that it could be the problem and i personally hope it is.
On another note, from now on please do not post useless bull sh*t without backing it up.
Old Sep 15, 2006 | 12:57 PM
Alright so today i found some interesting things. After replacing the fuse, altenator showed 15.5ish volts, hooked up to battery went down to 14.45v which is all normal. Now the weird part, i had the car running, everything hooked up and all seemed normal. After 20 minutes of ideling i decided to look at the speed sensor. Pulled out the clip and that blew the fuse. Could my VSS be bad and cause the short? This is getting really frustrating
Old Sep 15, 2006 | 08:44 PM
BLUE EH3's Avatar
Help we my pennies
when my speed stop working 2 mins later my alt fuse when
Old Sep 15, 2006 | 11:34 PM
vlc92189's Avatar
for the speedo not working.. yeah the VSS could be the problem... dont know bout the fuse though bro
Old Sep 17, 2006 | 11:00 AM
jdeemseerx's Avatar
..get underneath the car and look up at your intake mani bracket..there is a service bulletin about this problem.. check out the harness at and around that location.. check for any chewed wires you'll find something i bet good luck
nolimitlowrider
Mar 16, 2019 06:49 PM
mugen94
Nov 9, 2014 03:56 PM
aymen_a22
Dec 24, 2013 09:07 PM
jbarker
Aug 31, 2010 01:23 PM
