serivce interval on the fuel filter
Old Sep 14, 2006 | 04:51 AM
erottik-R's Avatar
Default serivce interval on the fuel filter
Was told by dealership it is a lifetime part that only needs changing when theres a problem.
I could have sworn that it has to be changed every 30,000
Also, can I get the correct ITR fuel filter pt #?
TIA
Old Sep 14, 2006 | 05:01 AM
Dave_B's Avatar
I personally believe in preventative maintenance so I change mine every 15k.
Old Sep 14, 2006 | 05:21 AM
Ed 341's Avatar
Default Re: serivce interval on the fuel filter (erottik-R)
I thought they are supposed to last about 60,000 miles. Mine gave out around 100,000.
Preventive maintenance is easiest though...plus its like $30.
Old Sep 14, 2006 | 07:28 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erottik-R &raquo;</TD></TR><TR><TD CLASS="quote">Was told by dealership it is a lifetime part that only needs changing when theres a problem.
TIA</TD></TR></TABLE>
What they told you is true. Honda doesnt replace them until its a problem.
Dave, thats overkill!!!
Old Sep 14, 2006 | 07:34 AM
Dave_B's Avatar
Default Re: serivce interval on the fuel filter (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">
Dave, thats overkill!!!</TD></TR></TABLE>
Ha, you should see how often I change plugs then...
&lt;---- get's parts at a discount and always changes shiz early.
Old Sep 14, 2006 | 07:36 AM
cool guy name
Default Re: serivce interval on the fuel filter (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">
&lt;---- get's parts at a discount and always changes shiz early.</TD></TR></TABLE>
Plugs I can agree on but a fuel filter is just not getting dirty enough to change that often.....but tooo eachh hiiss ownnn
Old Sep 14, 2006 | 08:18 AM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">Ha, you should see how often I change plugs then...
Mail me all of the old parts, I'll pay shipping.
After all, I know your showcar isn't driven hard at all.
Old Sep 14, 2006 | 08:33 AM
Dave_B's Avatar
Default Re: serivce interval on the fuel filter (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">
After all, I know your showcar isn't driven hard at all. </TD></TR></TABLE>
You want them shipped to Japan or HI?
Old Sep 14, 2006 | 08:50 AM
walker111's Avatar
What I didn't realize is that it would take Dave approx 15 years to accumulate 15000 miles so therefore he is only replacing that stuff because they are rusting out!
Old Sep 14, 2006 | 10:07 AM
rcar97's Avatar
I change it when I'm doing a major tune up(cap, rotor, plugs etc..) for the $ why not. A clogged fuel filter can really hurt performance. It good to do so you can rule it out as a potential problem. PM is worth the time and $ if you have a nice car like an R
Old Sep 14, 2006 | 02:34 PM
01usjdmr's Avatar
My car started sputtering. I changed it at 50k it solved my problem.
Old Sep 14, 2006 | 06:23 PM
uNF$@#!'s Avatar
Default Re: (01usjdmr)
fuel filters on the rsx and newer cars many acura techs will tell you will last the life of the car. strangely enough i've heard there isnt a whole lot different about the fuel filters in the rsx compared to integra.
that said, when i removed my fuel filter at 15k, it looks brand spanking new, which it pretty much was.
Old Sep 14, 2006 | 06:53 PM
b19coupe's Avatar
Honda changed the service interval of the fuel filter without changing the design significantly. I would say 60k is a good service interval-more often if you use shitty gas. When you pull the filter off look at the fuel that drains out. If it comes out black with lots of debris, it was due. If the fuel looks fairly clean, then it has more life left in it. The service life of the fuel filter is determined by the quality of fuel that it sees.
Old Sep 15, 2006 | 11:03 AM
erottik-R's Avatar
Thanks for all the responses.
I suppose at 121,xxx it's due for a change. Bad gas or not.
/erottik-R
jhony_ej6
Jul 11, 2008 09:55 AM
jmaz
Honda Civic (2006 - 2015)
Aug 8, 2007 04:30 AM
CBURKE
Jul 26, 2006 06:30 AM
rasinhell
14
Mar 31, 2005 11:01 AM
99lude
Dec 8, 2003 06:57 AM
