apexi-v-afc/ any gain on n/a motor?
i plan on getting one.might go turbo dont know yet.any gain from this on na setup?
i pulled my plugs out yesterday and they are blck.not oil, rich running black,you can feel the car kind of bog at low rpm for a sec.thats why i pulled the plugs out.
any help on this?
the setup is below.
[Modified by 4gvtec, 3:46 AM 4/30/2002]
any help on this?
the setup is below.
well youll get to tune alot better with the v-afc.
as four your running rich,i would change the fpr setting or if its a vtec fpr put the non vtec fpr back on.
the vtec fpr runs a higher psi,the non vtec fpr will lean it out.
hope this helps.
hope this helps.
Guest
Posts: n/a
the afc part will work fine, the V part is only usefull w/ non stock vtec cams. http://macguyver.ath.cx/vafc.pdf do some reading before you blow 350$ on that thing
Casey
Sep 25, 2003 06:49 AM
