help with secondary o2 sensor
Old Sep 13, 2006 | 09:29 PM
viskii420's Avatar
Default help with secondary o2 sensor
i need help w. o2 sensor.. i just did a swap from y7 to y8... on y7 both of the sensors were on the headers.. and on the y8 there is the o2 sensor at cat.. since i swaped the wires also now i dont know how to make the secondary o2 sensor connected to ecu.. do i run just an other wire to ecu... or running w.out the secondary o2 sensor if is fine.. i did my search but couldnt find anything...
Thanks in advance.
Old Sep 13, 2006 | 09:35 PM
Luserkid's Avatar
Default Re: help with secondary o2 sensor (viskii420)
What wires did you swap? The 2nd o2 sensor should plug right into your harness.
Old Sep 13, 2006 | 09:36 PM
EL Vap133's Avatar
For the secondary o2, all you need to do is extend the wires right?
Old Sep 13, 2006 | 09:42 PM
viskii420's Avatar
the problem is that the harnes that i had for my y7 i sold em.. when i got the y8 i swaped it w. all the engine harnesses.. right now i see only the first o2 sensor.. o2 secondary should be at the cat conv.. so now im confuesed.. how to get the o2 sensor connected anywhere.. cuz i dont see any secondary wire
Old Sep 14, 2006 | 05:35 AM
viskii420's Avatar
help
Old Sep 16, 2006 | 05:59 AM
viskii420's Avatar
up
Old Sep 16, 2006 | 06:10 AM
krazyhmongboi's Avatar
try extending the wires..might throw some codes though..not shure..mine did when i put in a header and ex cat
Markadler47@gma
Mar 22, 2019 02:36 PM
NightHawkBlack-R
Feb 16, 2009 10:28 AM
AL ASPIRATED
Nov 11, 2003 10:34 PM
b18civic
Feb 2, 2002 08:59 PM
