GSR head on b16a (JDM) block
AS title...
does any one know what head gasket to use....
Is there any thing i need to look out for whale changing heads....
And does it matter it i a 97 gsr head going on a obd1 b16a block... if all the sensors plug in am i good to go...
Re: GSR head on b16a (tial-eg)
listen...your B16a head is a much better flowing head than the GSR on that you have...in fact most GSR people swap out their GSR head for a b16A head they flow better and have more capabilities for top end power. stick with your head and sell the GSR with the money you get buy something that will actuall ADD power...any other questions please lemme know ok
good luck (didn't mean to flame)
cute little bastard
Re: GSR head on b16a (JDM) block (tial-eg)
B-series VTEC head gaskets are interchangable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mighty_sol »</TD></TR><TR><TD CLASS="quote">listen...your B16a head is a much better flowing head than the GSR on that you have...in fact most GSR people swap out their GSR head for a b16A head they flow better and have more capabilities for top end power. stick with your head and sell the GSR with the money you get buy something that will actuall ADD power...any other questions please lemme know ok
good luck (didn't mean to flame)</TD></TR></TABLE>
It doesn't flow like an "insane" amount better. The GSR head gives more compression too but not a crazy amount. So both have their ups/downs.
Re: GSR head on b16a (mighty_sol)
The flow characteristics between a GSR and B16 head are negligable at best. The GSR will shine slightly more in the middle part of a power band, where the b16 will shine in the higher RPMs, but the differences aren't that considerable.
Much like adding GSR cams to a b16a head, the power differences are negliable at best - I've seen GSR cams in a b16a head lose a few horsepower through the power band.
I do agree though, keep your b16a head, do a port job and call it a day.
Re: GSR head on b16a (2000EM1)
are you boosting your car?? If so i would go with the GSR head but if you plan on staying n/a i would definetely keep the B16 head
cute little bastard
Re: GSR head on b16a (sqad_7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sqad_7 »</TD></TR><TR><TD CLASS="quote">are you boosting your car?? If so i would go with the GSR head but if you plan on staying n/a i would definetely keep the B16 head</TD></TR></TABLE>
What is your reasoning?
Re: GSR head on b16a (SkoundrelUSA)
Ok first of all raseing my over all compretion from 10/1 to 11.25/1
To let you all in b16a bottom end
GSR head (less domes higher compresstion)
B16b intack cam (there is the top end of b16b)
B18c1 exost came
dule valves
this is the set up.. and about the small increas more like 15 ***** befor vtec and a good 15-20 after after a good street tune...
and if i was boosting my car i would keep my b16 head ot take my head and put in on a gsr block.. 11.25/1 to high for any boost...
this is a huge compresstion change... i have looked you all the info... and the set up is like a goo0d ls-vtec... i gust needed info on the gaket i needed and the person that help me thx...
B18c1 exost came
dule valves
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tial-eg »</TD></TR><TR><TD CLASS="quote">Ok first of all raseing my over all compretion from 10/1 to 11.25/1
B18c1 exost came
dule valves
this is a huge compresstion change... i have looked you all the info... and the set up is like a goo0d ls-vtec... i gust needed info on the gaket i needed and the person that help me thx... </TD></TR></TABLE>
Since when does switching out a 10.2:1 compression b16a head for a 10.4:1 GSR head raise your compression to 11.25:1? How thin of a head gasket are you using here? I don't think that's possible, but I don't feel like looking up the numbers.
B18c1 exost came
dule valves
My understanding is that the gsr head yields about .2 higher compression than a b16 head. Flat valves maybe another .1 and another .1 with a thin headgasket. maybe .5 higher total compresson using all of these things together. assuming your using USDM gsr pistons you should see about 10.3 c/r. You should just go ahead and change pistons while your in there and get that 11:1 c/r. Go for type-r pistons, jdm will yeild more compression than usdm.
i am srcaping the trubo for now... and with a good chipped ecu and 2 ply head gaskets the comprestion will jump alot...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tial-eg »</TD></TR><TR><TD CLASS="quote">i am srcaping the trubo for now... and with a good chipped ecu and 2 ply head gaskets the comprestion will jump alot... </TD></TR></TABLE>
Yea that chipped ecu will really bump it up
Keep the b16 head.
Keep the b16 head.
mannyman2
05-03-2008 12:04 AM
spoon95eg
02-26-2006 01:16 PM
