B16A1 with Y1 trans = which clutch & flywheel (by vehicle & eng. model pls) - what works?
I believe flywheel can be from 99-00 Si, 90-91 Integra (but I don't know which engine), or 93-94 del sol VTEC.
Clutch should be for 90-91 Integra only?? How is that? clutchcityonline.com notation for this clutch says 25mm spline - is that correct?? Anyone, and I mean ANYONE used another clutch setup successfully with their swap (B16A1 with Y1)?
Your help is most appreciated.
Thank you all
Thank you all
25mm spline like the 90-91 USDM integras.
99+ SI flywheels only accept 6 bolts for the pressure plate.
90+ Integra Flywheels are 9 bolts.
All pressure plates for the B-series are compatible but 99+ SI's are 6 bolts instead of 9 bolts.
Drop me a line if you have more questions. I know a **** load about clutches.
Thank you, Rocket! Guess stock replacement for 90 Integra is out of the question, or is the actual application for the B18B (having more torque?); and therfore, can a stock replacement last in a B16A1 application?
If you plan to do any type of spirited driving do not use organic. I say this all the time and I'll say it again. Organic linings and sprung hubs are not for racing. Organic lining is like cookie dough compared to other materials available. The springs in the hubs are waiting to pop out. What's better a hammer with a solid handle or a three piece one with springs.
Also if you like to downshift you should get a "Clipless" pressure plate. ACT, Action, and some HondaClutc(Herson) have this design.
Here is a pic of a clip. They tweak on downshifts and rub on the cover and prevent clutch disengagement.
Rocket - you are the man!
Thank you for the detailed info!
Deal on clutches = where??
Deal on JUN flywheel = where??
i've got a clutchmasters 6-puck unsprung clutch w/pressure plate for b16a cable tranny's
send me an im if interested for pics
integraautox
Jan 23, 2003 01:14 PM
