Question about distributor
Old Sep 13, 2006 | 02:19 PM
Si_chRis's Avatar
Default Question about distributor
When you go to retard or advance the timing on the distributor, there are 3 bolts to loosen it. When i did mine, i loosened the top one but then found out the two bottom bolts are just about loose enough to move the distributor. Are all three bolts supposed to be tightened like the top one after u set it? i just tightened the top one since thats how it was but im not sure if the other two needs to be tightened. Can someone verify this?
Old Sep 13, 2006 | 02:49 PM
JDM-EJ698's Avatar
Default Re: Question about distributor (EM1_ChRiS)
all three are supposed to be tight.
Old Sep 13, 2006 | 02:51 PM
SkoundrelUSA's Avatar
cute little bastard
lol yes. thats what bolts are for
Old Sep 13, 2006 | 03:03 PM
Si_chRis's Avatar
Default Re: Question about distributor (SkoundrelUSA)
ok, thanks. i hope it doesn't mess up anything because the previous owner had it with just the top bolt tightened and the bottom loose enough to move the dist.
Old Sep 13, 2006 | 03:06 PM
FalkenSiR's Avatar
Don't worry. The distribuitor will change timing only if the service connector is jumped.
Old Sep 13, 2006 | 03:12 PM
cute little bastard
Default Re: Question about distributor (fast95eg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 &raquo;</TD></TR><TR><TD CLASS="quote">Don't worry. The distribuitor will change timing only if the service connector is jumped.</TD></TR></TABLE>
huh? If the distributor is loose timing can def get messed up without having to jump the connector
Old Sep 13, 2006 | 03:34 PM
Si_chRis's Avatar
oh, the distributor isnt loose, it's pretty solid tight with just that one bolt on top. The other two bolts are only tightened enough to contact the dist. surface housing but still loose enough so when u loosen the top one, u can move the dist. for adjustment. I just haven't had time to tighten them since I'm away at college and due to the fact, i have the freakin password intake that takes up the space to reach those bolts. But other than that, the dizzy hasn't moved and the car has no problems running but i do want to tighten them up for sure
Old Sep 13, 2006 | 03:44 PM
cute little bastard
eh, just get an open ended 12mm and tighten them up decently. Because oil could also leak. I didn't have a bolt on the side one and was leaking...
Old Sep 13, 2006 | 03:45 PM
Si_chRis's Avatar
o damn, that must've sucked but mine hasn't leaked oil, well not that I know of.
PatrickGSR94
Aug 16, 2016 12:31 PM
bayoufrogg
Jul 27, 2005 11:17 AM
typeeg
Jun 8, 2004 08:09 PM
viet4gvtec
Apr 20, 2003 08:50 PM
sicivic
Oct 21, 2001 11:19 PM
