Disable secondaries on GSR running chipped P28?
I have a chipped p28 w/ an uberdata basemap... will i need to disable the secondaries on the intake manifold when my turbo setup is installed? This is a obd2b integra. Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweekerz »</TD></TR><TR><TD CLASS="quote">I have a chipped p28 w/ an uberdata basemap... will i need to disable the secondaries on the intake manifold when my turbo setup is installed? This is a obd2b integra. Thanks!</TD></TR></TABLE>
http://www.pgmfi.org/twiki/bin...ToP28
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dollar_bill »</TD></TR><TR><TD CLASS="quote">YES! simple modification to the secondary actuator should be just fine
or you can purchase an intake manifold from an after market vendor.
good luck.</TD></TR></TABLE>
Thanks for the info.
Is it true Ill lose some power below vtec? Getting a single stage IM is not an option right now.. already spent $$$. Maybe later down the line.
