Boosting a Stock B18c5
Old Sep 13, 2006 | 09:52 AM
Spec R_GSR's Avatar
Default Boosting a Stock B18c5
from experience what is the best turbo kit to use for this purpose expected power gains around 350+ hp also what management is good for this........
Old Sep 13, 2006 | 09:54 AM
white rocket's Avatar
Default Re: Boosting a Stock B18c5 (Spec R_GSR)
PM user Dr. Pooface. He had a stock c5 boosted for a while. It now has a built bottom end.
Old Sep 13, 2006 | 09:59 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: Boosting a Stock B18c5 (white rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spec R_GSR &raquo;</TD></TR><TR><TD CLASS="quote">from experience what is the best turbo kit to use for this purpose expected power gains around 350+ hp also what management is good for this........</TD></TR></TABLE>
The Tornado!!!!!
Old Sep 13, 2006 | 10:04 AM
Spec R_GSR's Avatar
Default Re: Boosting a Stock B18c5 (walker111)
the tornado wuz that?
Old Sep 13, 2006 | 10:07 AM
SiR99's Avatar
I dont think a stock c5 can handle 350whp for very long. Usually its around 300whp if you want it to last long enough to enoy it.
Old Sep 13, 2006 | 10:51 AM
CW-ITR's Avatar
Default Re: Boosting a Stock B18c5 (SiR99)
The high compression from the stock motor will eventually back fire on ya. The least you can do is lower the compression and stay under 300WHP.
Old Sep 13, 2006 | 10:58 AM
rizen's Avatar
I yanked 308 out of the motor on a stock block. Lasted a while in the hot Floridian heat... the key is to get a great tune out of it. Scrap the blue box or whatever comes with the "kit" your buying and get a hondata, AEM, or something capable of making that setup reliable.
Old Sep 13, 2006 | 11:28 AM
PM-Performance's Avatar
Default Re: Boosting a Stock B18c5 (CW-ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW-ITR &raquo;</TD></TR><TR><TD CLASS="quote">The high compression from the stock motor will eventually back fire on ya. The least you can do is lower the compression and stay under 300WHP.</TD></TR></TABLE>
Actually, what will backfire on you is the shitty stock pistons. The ring lands literally just fall apart. The compression is just something people like to talk about that really isnt all that much of an issue
Old Sep 13, 2006 | 12:15 PM
CRVRX's Avatar
Default Re: Boosting a Stock B18c5 (PM-Performance)
With a nice set up you do 300 on the stock motor, we run them a little fat under boost . Much over 300 and I would build it , 300 is enough to get you hooked
Old Sep 13, 2006 | 01:01 PM
CW-ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PM-Performance &raquo;</TD></TR><TR><TD CLASS="quote">
Actually, what will backfire on you is the shitty stock pistons. The ring lands literally just fall apart. The compression is just something people like to talk about that really isnt all that much of an issue</TD></TR></TABLE>Isn't high compression in booted motor causing more heat/detonation(SP) and therefore, lead to stock pistons failure???
Old Sep 13, 2006 | 06:11 PM
cambopheonix56's Avatar
Stay under 300whp.
Old Sep 13, 2006 | 06:25 PM
Finland's Avatar
I don't care how good the tune is the stock ringlands will not take much over 300whp forever. Mine lasted 40K miles on 295whp (mustang dyno).
350 on stock pistons...dream on.
Old Sep 14, 2006 | 07:47 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW-ITR &raquo;</TD></TR><TR><TD CLASS="quote">Isn't high compression in booted motor causing more heat/detonation(SP) and therefore, lead to stock pistons failure???</TD></TR></TABLE>
IMO, No, Its just that they are cast pistons and that is known to happen on cast pistons.
I have no proof as to why they break , but I can tell you that will be the first thing that will break if you are on a good tune.
Compression means nothing more then how much power and boost you can run on pump gas really.
There are cars with more compression the 10.6:1 making 1000whp. the difference is they do it on forged pistons and race gas or meth .
84DA69
Oct 22, 2006 01:12 PM
hondafrk505
Sep 30, 2006 07:52 PM
hatchbackjdm
Nov 7, 2005 06:19 PM
PAndADc2
10
Feb 3, 2005 08:23 PM
JunIntegra
Dec 13, 2003 08:44 AM
