smokeing problem
Old Sep 11, 2006 | 04:28 PM
streetcartuner's Avatar
Default smokeing problem
my 93 eg with a stock d15b7 smokes at high rpms someone please help and tell me what it might be the car also sat a while
Old Sep 11, 2006 | 04:31 PM
JDM-EJ1's Avatar
Default Re: smokeing problem (streetcartuner)
What color is the smoke?
Old Sep 11, 2006 | 04:36 PM
Default Re: smokeing problem (JDM-EJ1)
if i remember right i think its like a whitish
Old Sep 11, 2006 | 05:18 PM
B18c-EK's Avatar
i would say it needs the head rebuilt or that the rings are worn and your getting blow by, does it consume a noticeable amount of oil?
Old Sep 11, 2006 | 05:21 PM
old man neri's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetcartuner &raquo;</TD></TR><TR><TD CLASS="quote">if i remember right i think its like a whitish
White smoke is usually indicative of coolant entering the combustion chamber. What is the colour/level of your coolant?
Old Sep 11, 2006 | 05:22 PM
Default Re: smokeing problem (B18c-EK)
k thanx
a friend also thinks its the rings so ya do u think it will clear up if i drive it more
Old Sep 11, 2006 | 11:21 PM
ObedD15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetcartuner &raquo;</TD></TR><TR><TD CLASS="quote">k thanx
Being a Street Car Tuner as your names says you should already know that driving it more would only wear on the them out more not replace them for you. But you already know that.
Old Sep 14, 2006 | 09:04 AM
Default Re: smokeing problem (ObedD15)
expletive off obedd15 *** hole
Old Sep 14, 2006 | 09:09 AM
sicky's Avatar
grammer nawzi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ObedD15 &raquo;</TD></TR><TR><TD CLASS="quote">
Being a Street Car Tuner as your names says you should already know that driving it more would only wear on the them out more not replace them for you. But you already know that. </TD></TR></TABLE>
Nice.
Anyways, sounds like you might need a new head gasket.
Old Sep 14, 2006 | 09:21 AM
mikeycivic's Avatar
Default Re: smokeing problem (sicky)
when is the last time water pump and t-belt was done. Oil smoke is blue whiteish/gray smoke os water
azn_ignite
Feb 3, 2008 12:58 PM
R.I.P 2000 Si
Dec 18, 2007 09:06 PM
hcivic99
16
Apr 5, 2006 02:26 PM
escape2me
Jun 29, 2005 11:24 AM
SpoolinEK
11
Dec 7, 2003 02:40 PM
