Question about B-series swap on a EJ8?
Old Sep 11, 2006 | 09:13 AM
JesusGLS's Avatar
Default Question about B-series swap on a EJ8?
I was wondering what stock mounts from my 97 Civic with a SOHC engine can be use when making a B-series swap? I'm going to start the swap today but haven't purchase any mounts yet, so I was wondering which stock mounts I can use. I would really appreciated if someone could help me out. THANKS!!
Old Sep 11, 2006 | 09:19 AM
Luserkid's Avatar
Default Re: Question about B-series swap on a EJ8? (JesusGLS)
Stock mounts, 99-00 SI brackets.
Old Sep 11, 2006 | 10:55 AM
skunkcoupe's Avatar
Default Re: Question about B-series swap on a EJ8? (Luserkid)
u cant use any stock mounts from the sohc i dont think! just need 99-00 si mounts!
Old Sep 11, 2006 | 11:27 AM
eeleaj's Avatar
Default Re: Question about B-series swap on a EJ8? (skunkcoupe)
yeah i dont think you can use the stock d mounts at all
Old Sep 11, 2006 | 08:09 PM
JesusGLS's Avatar
Default Re: Question about B-series swap on a EJ8? (eeleaj)
O IC........has anyone tried using the stock mounts before to see if they fit? Or are you just suggesting they don't fit? Don't mean this in a bad way just wondering to see if it has already been tried.
Old Sep 11, 2006 | 08:12 PM
SovXietday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Stock mounts, 99-00 SI brackets. </TD></TR></TABLE>
A lotta "don't thinks" in this thread.
Old Sep 11, 2006 | 08:15 PM
JesusGLS's Avatar
Default Re: Question about B-series swap on a EJ8? (SovXietday)
So then I just buy the 99-00 brackets? Which ones do I need?
Old Sep 13, 2006 | 01:11 PM
skunkcoupe's Avatar
all of them
Old Sep 13, 2006 | 02:18 PM
ek_chris's Avatar
you need the rear tranny bracket.. it's shaped like a T. You also need the bracket on the driver side that bolts to where your timing cover is. Both from an SI. You also need the front two torque mounts from a teg or si.
Old Sep 13, 2006 | 03:44 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunkcoupe &raquo;</TD></TR><TR><TD CLASS="quote">u cant use any stock mounts from the sohc i dont think! just need 99-00 si mounts! </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eeleaj &raquo;</TD></TR><TR><TD CLASS="quote">yeah i dont think you can use the stock d mounts at all</TD></TR></TABLE>
No offense but do you 2 know the difference between a mount and a bracket?
Dasfinc
10
Feb 29, 2008 06:29 PM
90laser91civic
Feb 22, 2008 06:35 AM
guamie
Dec 19, 2006 10:22 AM
Top-Fuel
Mar 23, 2006 06:45 PM
Modern91Hatch
22
Dec 22, 2005 12:27 PM
