Can someone post up entire B-series tourque specs
i need to know the entire b-series tourque specs and i did search and i found threads that were only 1 specific thing and i need everything
http://en.wikipedia.org/wiki/Honda_B_engine
it's amazingly easy to find information on the WWW
Originally Posted by wiki wiki wiki pedia bitch
B16A
Note: All JDM B16a engines are marked as 'B16a' (with no number to identify version).
* VTEC
* Found in:
o 1989-1993 JDM Honda Integra RSi/XSi (DA6/DA8)
o 1989-1991 JDM Honda CRX SiR (EF8)
o 1989-1991 JDM Honda Civic SiR/SiRII (EF9)
+ Displacement: 1595 cm3
+ Compression: 10.2:1
+ Rod/stroke ratio: 1.74
+ Power: 158 hp @ 7600 rpm & 112 ft·lbf @ 7000 rpm
+ Transmission: S1/J1/Y1/A1
o 1991-1995 JDM Honda Civic SiR/SiRII (EG6/EG9)
+ Compression: 10.4:1
+ Power: 168 hp @ 7800 rpm & 116 ft·lbf @ 7300 rpm
+ Transmission: S4C
o 1992-1995 EDM Honda Civic VTi
+ Power: 158 hp @ 7800 rpm & 116 ft·lbf @ 7300 rpm
o 1992-1996 JDM Honda CR-X del Sol SiR
+ Compression: 10.2:1 / 10.4:1
+ Power: 158 hp - 170 hp & 111 ft·lbf - 116 ft·lbf
B16A1
* VTEC
* Found in:
o 1989-1991 EDM Honda CRX 1.6i/VTi (EE8/ED)
+ Power: 160 hp (117 kW) @ 7600 rpm & 111 ft·lbf (151 N·m) @ 7000 rpm
B16A2
* VTEC
o 1996-2000 Honda Civic VTiR (EK)
+ Power: 160 hp @ 7800 rpm & 113 ft·lbf @ 7300 rpm
o 1999-2000 Honda Civic Si (EM1)
+ Power: 160 hp (118 kW) @ 7600 rpm & 111 ft·lbf (151 N·m) @ 7000 rpm
+ Transmission: Y21 S4C
o 1996-1997 Honda Del Sol VTEC (EG)
+ Power: 170 hp (125 kW) @ 7800 rpm & 111 ft·lbf (152 N·m) @ 7000 rpm
+ Transmission: Y21
B16A3
* VTEC
* Found in:
o 1994-1995 Honda Del Sol VTEC (EG)
+ Power: 160 hp (125 kW) @ 7800 rpm & 111 ft·lbf (152 N·m) @ 7000 rpm
+ Transmission: Y21
B16B
* VTEC
* Found in:
o 1997-2000 Civic Type-R
+ Compression: 10.8:1
+ Power: 187 hp (137 kW) @ 8200 rpm & 118 ft·lbf (160 N·m) @ 7500 rpm
+ Transmission: S4C WITH LSD
B17
B17A1
* VTEC
* Found in:
o 1992-1993 Integra GS-R (DB2)
+ Displacement: 1678 cm3
+ Compression: 10.0:1
+ Power: 160 hp @ 7600 rpm & 117 ft·lb (159 N·m) @ 7000 rpm
+ Transmission: Cable~ YS1
B18
B18A
* Non-VTEC
* Found in:
o 1986-1989 Accord Aerodeck LXR-S/LX-S (Japan)
o 1986-1989 Accord EXL-S/EX-S (Japan)
o 1986-1989 Vigor MXL-S (Japan)
+ Displacement: 1834 cm3
+ Compression: 9.4:1
+ Dual Keihin Carbs
+ Power: 130 hp (97 kW) @ 6000 rpm & 120 ft·lbf (164 N·m) @ 4000 rpm
+ Transmission: A2N5, E2N5
* This engine is not 100% related to the other B series engines. It is a destroked Honda B20A engine.
B18A1
* Non-VTEC
* Found in:
o 1990-1993 Integra RS/LS/GS (DA)
+ Compression: 9.2:1
+ Bore: 81 mm
+ Stroke: 89 mm
+ Power:
# 1990-1991: 130 hp (97 kW) @ 6000 rpm & 121 ft·lbf (164 N·m) @ 5000 rpm
# 1992-1993: 140 hp (104 kW) @ 6300 rpm & 127 ft·lbf (173 N·m) @ 5200 rpm
+ Transmission: YS1
B18B1
* Found in:
o 1994-2001 Acura Integra "RS/LS/GS" (DC4)
+ Displacement: 1834 cc
+ Bore: 81 mm
+ Stroke: 89 mm
+ Power:
# 142 hp (104 kW) @ 6300 rpm & 128 ft·lbf @ 5200 rpm
+ Transmission: S80
B18C
* VTEC
* Found in:
o 1994 Honda Integra SiR-G
o 1995-1997 Honda Integra SiR
* Power: 180 hp (128 kW)
o 1997-2001 Honda Integra (Japan) Type R
* Power: 200 hp @ 8100 rpm
B18C1
* VTEC
* Found in:
o 1994-2001 Integra GS-R (DC2)
* Displacement: 1797 cm3
* Compression: 10.0:1
* Power: 170 hp (127 kW) @ 7600 rpm & 128 ft·lbf (174 N·m) @ 6200 rpm
* Transmission: Y80
B18C3
* VTEC
* Found in:
o 1995-1998 Acura Integra Type R
Power: 195 hp
B18C4
* VTEC
* Found in:
o 1996-2000 UK Civic 1.8i VTi Acura Integra
* Power: 169 hp (124 kW) @ 8000 rpm & 129 ft·lbf (174 N·m) @ 7500 rpm
* Transmission: S9B
B18C5
* VTEC
* Found in:
o 1997-2001 Integra Type-R
* Compression: 10.6:1
* Power: 195 hp (145 kW) @ 8000 rpm & 130 ft·lbf (176 N·m) @ 7500 rpm
* Transmission: S80
B18C6
* VTEC
* Found in:
o 1998-2001 Honda Integra Type Rx
* Power: 200 hp (141 kW), 136 ft·lbf
B18C7
* VTEC
* Found in:
o 1996- Honda Integra Type R (Australia)
B20
The B20A3 and B20A5 are not considered part of the B family. See Honda B20A engine.
B20B
* Non-VTEC
* Found in: Honda CR-V, Honda Orthia
* Displacement: 1973
* Power: 126 bhp @ 5400 rpm
* Torque: 133 ft·lbs @ 4300 rpm
* Compression: 8.8:1
* Bore: 84 mm
* Stroke: 89 mm
* Redline: 6200 RPM
B20Z
* Non-VTEC
* Power: 146 bhp @ 6200 rpm
* Torque: 133 ft·lbs @ 4500 rpm
* Compression: 9.6:1
* Bore: 84 mm
* Stroke: 89 mm
* Redline: 6700 RPM
* VTEC
* Found in:
+ Transmission: S4C
B16A1
* VTEC
* Found in:
B16A2
* VTEC
+ Transmission: Y21
B16A3
* VTEC
* Found in:
+ Transmission: Y21
B16B
* VTEC
* Found in:
B17
B17A1
* VTEC
* Found in:
B18
B18A
* Non-VTEC
* Found in:
+ Dual Keihin Carbs
B18A1
* Non-VTEC
* Found in:
+ Bore: 81 mm
+ Stroke: 89 mm
+ Power:
+ Transmission: YS1
B18B1
* Found in:
+ Bore: 81 mm
+ Stroke: 89 mm
+ Power:
+ Transmission: S80
B18C
* VTEC
* Found in:
B18C1
* VTEC
* Found in:
* Transmission: Y80
B18C3
* VTEC
* Found in:
Power: 195 hp
B18C4
* VTEC
* Found in:
* Transmission: S9B
B18C5
* VTEC
* Found in:
* Transmission: S80
B18C6
* VTEC
* Found in:
B18C7
* VTEC
* Found in:
B20
B20B
* Non-VTEC
* Bore: 84 mm
* Stroke: 89 mm
* Redline: 6200 RPM
B20Z
* Non-VTEC
* Bore: 84 mm
* Stroke: 89 mm
* Redline: 6700 RPM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salman »</TD></TR><TR><TD CLASS="quote">where are the Spec, I cant find them any where,</TD></TR></TABLE>
what?
what?
TaffetaEj6
18
Jan 5, 2016 02:54 PM
BlackHXCoupe
Jul 21, 2006 12:48 PM
BlackHXCoupe
Northern California (Sales)
11
Jul 19, 2006 09:43 PM
so wheres the tourque at
