well i blew a headgasket, pulled it off and this is what i found, also wondering whp limits of 85mm
Old Sep 9, 2006 | 12:00 AM
Cimburke23's Avatar
Default well i blew a headgasket, pulled it off and this is what i found, also wondering whp limits of 85mm
well i had the car at the track a few weeks ago, noticed the water temp was going up after every run, checked the overflow and it was full, blown headgasket, simple fix, has happened before. well the car sits for about a week and i finally pull the head off and find this in cyl #2:
it looks as though the water wetter has alkaline in it and possibly embedded itself in the sleeve, these are AEBS sleeves. do you think i can bore this .5mm or 1mm over and get away with it? current bore is 84mm, i was wondering what the whp limits are on a boosted 85mm block w. AEBS sleeves. any help would be greatly appreciated
Old Sep 9, 2006 | 05:29 AM
Danny_EJ's Avatar
84.5 and call it a day. Although you may be able to get away with a standard hone and re ring it
Old Sep 9, 2006 | 05:51 AM
nowtype's Avatar
Default Re: (Danny_EJ)
I'd try to go to 84.5mm, but if it didn't do the job, I wouldn't think twice about going to 85mm. If/when it blows at 85mm, you can sell it to an NA guy
Old Sep 9, 2006 | 06:20 AM
tony1's Avatar
Default Re: (nowtype)
I've made close to 1000hp with 85mm bore on race cars, i think you'll be fine.
Old Sep 9, 2006 | 08:27 AM
Cimburke23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danny_EJ &raquo;</TD></TR><TR><TD CLASS="quote">84.5 and call it a day. Although you may be able to get away with a standard hone and re ring it</TD></TR></TABLE> ran a hone through it and it didnt even touch it , has anyone else heard of this problem with water wetter? what so you run in ur engines?
Old Sep 9, 2006 | 08:28 AM
Innes's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">I've made close to 1000hp with 85mm bore on race cars, i think you'll be fine. </TD></TR></TABLE>
was that in utah?
i concur - we ran an 85mm bore engine for pretty much 2 seasons making 700 ish whp
Old Sep 9, 2006 | 08:44 AM
tony1's Avatar
Default Re: (MazworxRaceSupply)
No, it was on a dynapack.
Old Sep 11, 2006 | 03:09 PM
Cimburke23's Avatar
Default Re: (tony1)
anyone have an idea of what would cause this?
Old Sep 11, 2006 | 04:02 PM
non-VTEC's Avatar
Default Re: (Cimburke23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cimburke23 &raquo;</TD></TR><TR><TD CLASS="quote">anyone have an idea of what would cause this?</TD></TR></TABLE>
dont know...burning coolant?....but by looking at the other two cylinders i would say you have some tuning issues also.
have the bores measured. you might get away with a hone job and new pistons/rings. or else 85.4mm
Old Sep 13, 2006 | 09:39 PM
Cimburke23's Avatar
Default Re: (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">dont know...burning coolant?....but by looking at the other two cylinders i would say you have some tuning issues also.
have the bores measured. you might get away with a hone job and new pistons/rings. or else 85.4mm </TD></TR></TABLE> what type of tuning issues? AFR or timing or what??? well im going at least 84.5mm anyway and putting an LS crank in it.
Modified by Cimburke23 at 10:54 PM 9/13/2006
Old Sep 13, 2006 | 09:56 PM
BoostedJeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MazworxRaceSupply &raquo;</TD></TR><TR><TD CLASS="quote">was that in utah?
i concur - we ran an 85mm bore engine for pretty much 2 seasons making 700 ish whp</TD></TR></TABLE>
no, no, no... in utah thats 1500whp
DC Love
Jan 26, 2008 09:24 AM
SPOOLINmatt
May 1, 2006 12:22 PM
92HB_HB
Mar 8, 2005 01:30 PM
mmuller
Oct 9, 2004 08:02 PM
integRated109
Sep 4, 2002 01:09 PM
