dizzy o-ring replacement
correct me if im wrong to replace the o-ring all i got to do is mark the top bolt where it is then unbolt the 3 bolts on the dizzy pull it out, take old ring off, oil new ring and then reinstall just the way I took it off correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">You are correct sir.</TD></TR></TABLE>thanx just makin sure
Make sure you make some sort of a mark so that the distributor goes into the same position after you reinstall it - that way you won't screw up your timing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dynamo »</TD></TR><TR><TD CLASS="quote">Make sure you make some sort of a mark so that the distributor goes into the same position after you reinstall it - that way you won't screw up your timing.</TD></TR></TABLE>the shaft has a slot y would I have to mark it if I put it back in the way I take it out I should have no problem rt?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondachris1994 »</TD></TR><TR><TD CLASS="quote">the shaft has a slot y would I have to mark it if I put it back in the way I take it out I should have no problem rt?
that shaft is slightly offset to one side.it must go back on in the same orientation.
if you look at the slot in the cam and the groove on the dizzy,you can see the offset.just match them up.if the distributor doesn't want to go back on straight,it may be 180 degrees off.don't force it-take it off and check the position of the keyway.
Chris
Chris
here, hope this helps:
https://honda-tech.com/zerothread?id=1065831
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">here, hope this helps:
https://honda-tech.com/zerothread?id=1065831</TD></TR></TABLE>
explains it very well
just keep in mind that if you turn the rotor,it's no big deal.just make sure you align it like i said above before installing it.
Chris
Chris
https://honda-tech.com/zerothread?id=1065831</TD></TR></TABLE>good find, that explains it very simple thanx guys---Chris, I b dammned if I was goin to pay someone to do that
david
Nov 30, 2005 02:01 PM
DougNuts
Sep 21, 2005 04:38 AM
