sound like a good d16y8 build up for boost?
Old Sep 8, 2006 | 09:59 PM
coreyhayman's Avatar
Default sound like a good d16y8 build up for boost?
im going to be building the motor in my 2000 civic si (canadian si), i wanna boost it and see some nice numbers, what do you think of the set up i got in mind? also what kinda boost you think it will beable to handle? power it will hold till?i wanna see over 300whp, it will be fully tuned and have all the appropriate fuel managment.
edelbrock performer x intake
srp dished forged pistons
scat forged rods
full arp hardware throughout
cometic head gasket
zex cam
skunk 2 valve springs
skunk 2 valves
golden eagle block guard
aem cam gear
scat forged crank
head p&p
lightened flywheel, stage 3 clutch, yada,yada
revhard turbo kit, yada,yada
Old Sep 9, 2006 | 05:57 AM
platinum00's Avatar
Default Re: sound like a good d16y8 build up for boost? (coreyhayman)
you can easily get 300whp.. save your money on the Scat crank. the OEM crank is perfectly fine.
platinum.
Old Sep 9, 2006 | 07:12 AM
AbitAvenger's Avatar
Default Re: sound like a good d16y8 build up for boost? (platinum00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">you can easily get 300whp.. save your money on the Scat crank. the OEM crank is perfectly fine.
platinum.</TD></TR></TABLE> ditto
Old Sep 9, 2006 | 07:28 AM
dornon13's Avatar
i Would probably save the money on the crank and put it into the turbo kit and put together something custom. but i know its not for everyone so the revhard is a good choice if you decide to go with a kit. whats your plans for engine management and fuel
Old Sep 9, 2006 | 07:35 AM
oscarmayer's Avatar
you don;t need an aftermarket crank. i run a stocker and make around 400 on pump and 20psi on my d16 motor.
Old Sep 9, 2006 | 08:31 AM
ok thanks guys, i really wasnt sure of how much the stock crank could hold, that will save me an easy 700 bucks right there, as far as fuel and management i havent really figured that part out yet. With the mods list i posted above how much power you think that motor would hold?
Old Sep 9, 2006 | 11:02 AM
TheHooded_Mike's Avatar
Default Re: (coreyhayman)
That setup should be good to ~450 I believe, but you don't even need to touch the head to hit 400 (or get really close).
Old Sep 9, 2006 | 09:47 PM
400whp would be very nice, the motor will be going into a 2000 civic si, id be happy to hit a mid 12 with the car. Think id beable to see over 350whp using the greddy kit?
Old Sep 10, 2006 | 07:12 AM
The 18g should be good for ~350 MAX.
Modified by TheHooded_Mike at 11:30 AM 9/10/2006
JDMNSX021
Nov 23, 2007 08:23 PM
91accordexr33
Aug 28, 2007 06:29 PM
saintspall
Mar 1, 2007 06:41 AM
mec. pedri
Feb 25, 2006 05:26 PM
rhd type r
Aug 28, 2005 01:29 PM
