Front Lip
my 97 bb6 came with the OEM accesorie lip. i too it off to clean behind it cuz my bumper was filthy behind the lip. i put the lip back on with the same clips & screws it comes to hold it from the bottom/sides and it doesnt fit flush, has some gaps now. any recommendations to what i can use to make it fit perfect?
well my lip only has clips/ screws on the sides. i believe it takes one in the front also but mine doesnt have them. when i bought the car it had a piece of a broken clip in the front under the lip so i took it off. and the whole front of the lip is all loose. i tryed some double stick tape and it worked but then started the gap problem on the side.
Also, where can i get bumper clips because both my front and back bumper sag a little bit and it gets on my nerves because i see the lips sagging inside. i want it to sit flush
Most preludes(BB6's) that I've seen have saggy bumpers. Some worse than others. My clips on the passenger front bumper(first one in front of the wheel) broke off so all i did was drill a couple small holes next to where the oem hole was and zip-tied it to the hole in the fender
quick fix until paint time.
ejONE.mike
13
Sep 24, 2005 08:13 PM
handa
Feb 24, 2005 01:51 PM
