IAB Sensor on 01 GSR engine in 99 Si
<FONT COLOR="royalblue"> I have a 01 GSR swap ( stock everything ) in my 99 SI . I ran the line directly to the ECU ( OBD1 GSR w/ Step Down Harness ) A17 ( Pin # 9 on the top row ). For some reason I can't get the Damm thing to work. Is there any difference bewteen the OBD1 & OBD2 IAB sensor? All the vac lines are connected, I just removed it from my 00 GSR and swaped it into my 99 SI. No CEL's, Virgin p72 Ecu. </FONT>
they are different. the wires are reversed. obd1 gsr sends a negative the iab while one side is connected to positive already. On obd2, the ecu sends a positive signal to the iab while the other side is connected to negative already.
fix the wiring and it should work
As long as I dont have to take out any more Metal Gears
so how would he fix that? connect the pos of the solenoid to a power source, while the other wire grounds into the ecu? I have an obd2 gsr in my car right now, and I'm thinking about converting to obd1, so I will need to fix this as well for my IABs
