EM1 Takes like 10 turnes to start the car after putting gas in
Old Sep 7, 2006 | 04:28 AM
TwoKSiR's Avatar
Default EM1 Takes like 10 turnes to start the car after putting gas in
Every time I put gas in my 2000 SiR it take forever to start after. I have a 255 pump in it. Any ideas?
Old Sep 7, 2006 | 06:06 AM
doublejz's Avatar
Default Re: EM1 Takes like 10 turnes to start the car after putting gas in (TwoKSiR)
sounds like the pressure isnt there... what happens if you turn the key and wait for the pump to prime (like wait 5-6 secs) then try to start it?
Old Sep 7, 2006 | 06:46 AM
malubawla's Avatar
Default Re: EM1 Takes like 10 turnes to start the car after putting gas in (doublejz)
clogged fuel filter?
Old Sep 7, 2006 | 07:44 AM
TwoKSiR's Avatar
new fuel filter, and i have ryed to prime it several times, its driving me nuts.
Old Sep 7, 2006 | 08:00 AM
the omen's Avatar
try opening ur fuel door and taking the gas cap off
get some1 to turn the switch on and listen for the pump 2 turn on
if no sound then
your connection to your fp could be bad
or the fuel pump is going out
i had the same prob with my eg 4dr
turned out to be a bad connection b/t the ecu and fp
Old Sep 7, 2006 | 08:59 AM
malubawla's Avatar
Default Re: EM1 Takes like 10 turnes to start the car after putting gas in (the omen)
or maybe your main relay is going bad....
Old Sep 7, 2006 | 10:26 AM
hondakevin21's Avatar
Default Re: EM1 Takes like 10 turnes to start the car after putting gas in (malubawla)
Check the fuse and then hook up a fuel pressure gauge.
Old Sep 8, 2006 | 08:58 AM
TwoKSiR's Avatar
I have a gauage and it looss pressure and regauns full pressure as soon as I prime it. Its a 255, I dont have to take the gas cap off to hear it, it make the same noise they all do.
Old Sep 8, 2006 | 09:33 AM
TwoKSiR's Avatar
https://honda-tech.com/zerothread?id=1742278
Old Sep 8, 2006 | 09:36 AM
kameleon23's Avatar
unplug your evap solenoid...worked for a ton of people..including me
Old Sep 9, 2006 | 09:36 AM
Dave4282's Avatar
Get a full-sized pic of the chick in your avatar
Old Sep 9, 2006 | 10:00 AM
Syndacate's Avatar
How the hell does that post help? That's an A/F Ratio guage...
He doesn't need an A/F ratio guage, he needs more pressure for whatever reason.
The pump is turning on or it wouldn' t be driving, so what's the possible corprits:
- clogged fuel filter (he said he changed it)
- FPR is fucked up (possible)
- fuel rail went...bad (unlikely)
- clogged injectors (still unlikely, or it'd be breaking up)
- evap purge solenoid (maybe..)
What else is there? I'm sure I'm leaving some **** out
Those are what I'd check first though...
Old Sep 13, 2006 | 09:51 PM
TwoKSiR's Avatar
Default Re: (Syndacate)
I posted the Air/Fuel gauge, its mine and I can't find the wiring diagram, I got alot of responces for this so I thought I would post the link here by chance.
The chick in my avatar is
http://www.jhpusa.com/catalog/...=1094
Its the JDM ***** t-Shirt that JHPUSA.com sells
And thanks for the help on the fuel pump issue. When I get my new motor in I will try the ideas. I got the pump from my firends DC2 and it didn't have any problems in it.
AdamCowie2000
Aug 10, 2014 03:43 PM
gtaccord
15
Mar 5, 2014 08:27 PM
RA12825
Jan 29, 2007 08:51 PM
B18Cej1
12
Nov 8, 2005 05:05 AM
ATS*Mark
Oct 26, 2004 08:16 AM
