98 JDM ITR pistons ...over sized or standard???
Old Sep 7, 2006 | 02:10 AM
wunPOINTeight's Avatar
Default 98 JDM ITR pistons ...over sized or standard???
im going to replace my piston rings but dont know if i need over size rings or standard .. help me find what i need PLEASE also maybe a link to a place that carries them ..
Old Sep 7, 2006 | 02:41 AM
sinister6's Avatar
Default Re: 98 JDM ITR pistons ...over sized or standard??? (wunPOINTeight)
why just the rings?
before order anything, i would take the head off and check the cylinder walls first if it need to be bored, as if the engine is already getting old and need to replace anything
Old Sep 7, 2006 | 03:09 AM
Dave_B's Avatar
Rings are dependant of the piston size. If your going with oversized pistons, then you'll want to get the matching oversized rings.
Old Sep 7, 2006 | 05:43 PM
Circuit Star-29's Avatar
Default Re: (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinister6 &raquo;</TD></TR><TR><TD CLASS="quote">why just the rings?
before order anything, i would take the head off and check the cylinder walls first if it need to be bored, as if the engine is already getting old and need to replace anything</TD></TR></TABLE>
I seriously doubt you would need to "Hone" or bore the cylinder. If hone marks are still visable, then its not needed. Per Honda recommendations...
Old Sep 7, 2006 | 10:14 PM
sinister6's Avatar
Default Re: (Circuit Star-29)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circuit Star-29 &raquo;</TD></TR><TR><TD CLASS="quote">
I seriously doubt you would need to "Hone" or bore the cylinder. If hone marks are still visable, then its not needed. Per Honda recommendations... </TD></TR></TABLE>
yes but why ONLY the rings is still in the question.
but if its stock use 81mm..
Old Sep 8, 2006 | 12:53 AM
Default Re: 98 JDM ITR pistons ...over sized or standard??? (sinister6)
the reason why im getting piston rings is because i was getting a little blue smoke at hig rpm. I have stock jdm itr pistons, i just needed to know what size piston rings i needed.
do you guys think i should replace the bearings with race acl's or im fine with stock to withstand 200whp?? motor has about 55-60k
specs on head
rocketmotorsprts valve train
rev flat face valves
crower spec2 cams
thanks for helping a newb guys
Modified by wunPOINTeight at 2:24 AM 9/8/2006
Old Sep 8, 2006 | 03:03 AM
sinister6's Avatar
blue= unburn fuel, get your car tuned before spending/replacing any crap.
for the bearing, i have been always told use OEM and color match them
Old Sep 8, 2006 | 05:26 AM
Ed 341's Avatar
Bottom line is you need to have the engine disassembled to know for sure what needs to be replaced.
If you upsize the rings you need to increase piston size and bore the cylinders.
Maybe someone could provide more info on the ACL bearings?
oh yeah http://inlinefour.com
Modified by Ed 341 at 7:23 AM 9/8/2006
Old Sep 8, 2006 | 10:53 AM
well the motor has been sitting for a wihile and its going in my 89 si hatch and wanted everything refreshed before the swap , it was tuned when it was in my eg a/f was coo ..
hmm oem bearings and color match them? , what do you mean color match ?
yeah any input on acl bearings?
i will be dissassemblng the motor this weekend and will take pics of the cyclinder walls and pistions with rings..
do you goys think ill be fine with the stock pistions for 2oowhp??
Old Sep 8, 2006 | 11:16 AM
Ed 341's Avatar
Sounds like you need to do a lot of research before you try to reassemble the motor.
Old Sep 8, 2006 | 11:29 AM
I really only have a bout an hour a day to do research ,* I have to watch my son and work 12 hours daily 5 days a week plus almost most my questions have been answerd in this thread. I just really want suggestions from you guys on my build ..
Old Sep 8, 2006 | 07:50 PM
RagingAngel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinister6 &raquo;</TD></TR><TR><TD CLASS="quote">blue= unburn fuel, get your car tuned before spending/replacing any crap.
blue = oil
black = fuel
To the OP, observe your oil consumption and do a compression check....leakdown might be a good idea as well.
Old Sep 9, 2006 | 02:31 AM
Default Re: 98 JDM ITR pistons ...over sized or standard??? (RagingAngel)
will do, will have pics up of motor later this weekend of motor
Old Sep 9, 2006 | 02:48 AM
tartje's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">
blue = oil
black = fuel
Old Sep 10, 2006 | 03:37 PM
Default Re: 98 JDM ITR pistons ...over sized or standard??? (tartje)
Pick up a manual and give it some good reading time... Bearings are coded by color depending on the thickness of the bearing. Most of the time you can just match the bearings to the crank and rod by the letters that are stamped on those pieces. but its still a good idea to plastigauge just to make sure.
Check out this site: http://www.hondahookup.com/manuals/
Further more, DO NOT use the ACL race bearings. These are not street car bearings. And from my experience, fork out the extra dough for the OEM bearings... ACL only gets you close and if you want to have a reliable motor go with the OEM...
Old Sep 10, 2006 | 07:55 PM
sinister6's Avatar
honestly I cant see blue smoke at all when my car burned 1qt per 500 km...
but i can see blue to black smoke now with a 4G63 sitting in tuner, its running limp mode so im supposing its running rich(fuel)?
i can see milky white smoke all the time but this prolly due to an un-tuned engine...
so im not so sure this is an individual case to me or Im missing something. I use Motul 300V btw, dont think it makes difference when it comes to the buring part.
someone could explain to a n00b (me)?
Modified by sinister6 at 9:18 PM 9/10/2006
Ep3tat98
K Series
Feb 3, 2016 10:20 PM
da_rimrocka
Nov 30, 2005 12:14 PM
Hapexamendios EJ8
Feb 19, 2005 11:04 PM
ludelvr
Nov 26, 2003 03:56 PM
SupaFly_Honda
Jan 21, 2003 06:53 AM
