posi or not?
Old Sep 6, 2006 | 07:26 PM
greddy2smoke's Avatar
Default posi or not?
i have a 95 honda Ex Coupe(Stick). and i need to know if is posi or 1 wheel drive cause im gonig to change the gear lube in the transmission and i need to know which one then to buy thanks!
Old Sep 6, 2006 | 07:38 PM
unknown0001's Avatar
Default Re: posi or not? (greddy2smoke)
The factory d-series engine that came in the US/CDN models did not come with LSD...aka..positraction.
You can use regular honda MTF or guy GM Synchromesh to hide any gear grinds
Old Sep 6, 2006 | 07:45 PM
Default Re: posi or not? (Mr.RHTuner)
so i can use regular honda MTF or guy GM Synchromesh for the tranny? what do you mean to hid any gear grinds?
Old Sep 6, 2006 | 07:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greddy2smoke &raquo;</TD></TR><TR><TD CLASS="quote">so i can use regular honda MTF or guy GM Synchromesh for the tranny? what do you mean to hid any gear grinds?</TD></TR></TABLE>
Yes you can use honda MTF for the tranny fluid.
You can use GM Synchromesh to hide any gear grinds you may have. Going from 2nd to 3rd might have a gear for example...if it's slight then GM synchromesh may help quiet it
96-EJ6 B18C's Avatar
Yeah, either one will work just fine.
If the tranny is grinding into gears, GM syncromesh has a tendency to make them go away.
Old Sep 6, 2006 | 07:53 PM
thank guys! i appriciate it!
Old Sep 7, 2006 | 06:11 PM
Default Re: (greddy2smoke)
okok guys my car is posi! so now i need to know what to buy for muh fluids! Er.......
Old Sep 7, 2006 | 06:15 PM
schardbody's Avatar
no it doesnt, put one wheel on a wet grass patch, and the other on dry concrete, drop the clutch, and watch that one wheel spin.
better yet, jack up just one front wheel, leave the other in full contact w/ the ground, ease out on the clutch in second gear, and see if it jumps off the jack.
Old Sep 7, 2006 | 06:42 PM
shibiku's Avatar
Default Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">no it doesnt, put one wheel on a wet grass patch, and the other on dry concrete, drop the clutch, and watch that one wheel spin.
better yet, jack up just one front wheel, leave the other in full contact w/ the ground, ease out on the clutch in second gear, and see if it jumps off the jack.</TD></TR></TABLE>
LOL, good test
Old Sep 7, 2006 | 07:16 PM
what do you mean jump the jack?
Old Sep 7, 2006 | 08:01 PM
Padawan's Avatar
Darth ModerVader
Just use Honda MTF - end of story.
Old Sep 7, 2006 | 08:07 PM
Eran's Avatar
HT White Ops
Next time you use "posi" to describe your Honda, I'm gonna e-kick you in your e-*********.
You don't drive a chevy, and your car doesn't have an LSD.
Old Sep 8, 2006 | 08:03 AM
schardbody's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greddy2smoke &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean jump the jack?</TD></TR></TABLE>
just do it and you will see if you have LSD
Old Sep 8, 2006 | 08:15 AM
cambopheonix56's Avatar
100% sure its not posi, unless you dropped in a 350 or equivillent.
Old Sep 8, 2006 | 08:38 AM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greddy2smoke &raquo;</TD></TR><TR><TD CLASS="quote">okok guys my car is posi! so now i need to know what to buy for muh fluids! Er.......</TD></TR></TABLE>
1.) Positraction is a Chevrolet term.
2.) if you have a D-series engine that originated in America you DO NOT have a limited slip differential. Period. Just because both wheels can turn at the same time does not mean that you have LSD. I'm getting so sick of explaining this to people. Put your car up on jack stands and gently release the clutch: both wheels spin. This does not prove anything.
3.) you have a Honda. Regardless of the state of the manual transmission, you use Honda MTF to fill it. Period. You may use Synchromesh Friction Modified if you have a grind that you want to take care of, but Honda MTF is your best bet for meeting all criteria without danger to any components.
Old Sep 8, 2006 | 01:52 PM
sauceja's Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
3.) you have a Honda. Regardless of the state of the manual transmission, you use Honda MTF to fill it. Period. You may use Synchromesh Friction Modified if you have a grind that you want to take care of, but Honda MTF is your best bet for meeting all criteria without danger to any components.</TD></TR></TABLE>
Old Sep 8, 2006 | 05:31 PM
ok then thats what im going to buy another question is my car for some reason i cant slam gears anymore, but only grinds going into 3rd unless i put alittle pressure on it ,it'll go in, is my tranny going soon or is there somthing i can do to help it?
Old Sep 8, 2006 | 05:33 PM
sorry guys im used to having a chevy, had a old school RS with a 350 and im used to american **** i guess
Old Sep 9, 2006 | 03:10 AM
schardbody's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">1.) Positraction is a Chevrolet term.
who said it did??? if one wheel has absolutely no traction and the other has full traction, the one off the groun will spin (non-LSD). i agree w/ everything you said, just making sure you dont think i said jack both wheels up.
Old Sep 16, 2006 | 04:57 AM
is there like a wieght in the gear lube? like 30 weigh or somehthing i need to get?
Old Sep 16, 2006 | 05:27 AM
ZacCarter's Avatar
No just go to honda, and get the mtf.
Old Sep 16, 2006 | 06:26 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greddy2smoke &raquo;</TD></TR><TR><TD CLASS="quote">is there like a wieght in the gear lube? like 30 weigh or somehthing i need to get?</TD></TR></TABLE>
It isn't gear lube, it is manual transmission fluid. As others have repeatedly stated, go to your local Honda or Acura dealer and ask them for manual transmission fluid. Very simple.
jaidedeye
20
Feb 24, 2013 05:35 PM
RACEPAK
May 25, 2007 02:50 PM
trooper0641
18
May 6, 2005 06:50 PM
gooberwolf
Dec 3, 2003 11:50 PM
b20civic
Aug 26, 2002 08:24 PM
