Will GM Syncromesh fix my 3rd gear grind?
Old 05-04-2005, 09:02 PM
trooper0641's Avatar
Default Will GM Syncromesh fix my 3rd gear grind?
I've heard about this gm syncromesh and that it does "wonders". Does it really?
Well my tranny has been acting up on me lately. Slightly grinding into 3rd...I thought it was the tranny fluid, changed it from Honda MTF to some regular thick valvoline gear oil. Even made it worst. Went with 10w30 with a mix of the Lucas crap. And it sure made a world of a difference. But still...sometimes it grinds...
What are your opinions about GM?
Old 05-04-2005, 09:04 PM
Mr. Indecisive
EJ8VTEC's Avatar
Default Re: Will GM Syncromesh fix my 3rd gear grind? (trooper0641)
i heard it does wonders n is worth every penny
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 &raquo;</TD></TR><TR><TD CLASS="quote">I've heard about this gm syncromesh and that it does "wonders". Does it really?
What are your opinions about GM?</TD></TR></TABLE>
The Honda MTF is really awesome stuff. I have heard the GM syncromesh has fixed grinding problems in the past, but I think its really hit and miss. I would tell you to fix the damaged synchro the right way and replace it. Then stick with Honda MTF and change it at the regular intervals like you should.
Old 05-04-2005, 09:14 PM
Built Beast's Avatar
Honda MTF is just as good, and is much cheaper... It will fix a slight grind but it will be a temporary fix. It will not alleviate the problem all together though.
Old 05-04-2005, 09:17 PM
Risky Business
BauleyCivic's Avatar
Default Re: Will GM Syncromesh fix my 3rd gear grind? (Built Beast)
I used synchromesh, and I advise against it.
It does eliminate the grind, but it hesitates before you shift into gear, making your car slower. I like the way honda MTF shifts much better.
Old 05-04-2005, 09:21 PM
I am a (Trial User) Army
litterbox's Avatar
Default Re: Will GM Syncromesh fix my 3rd gear grind? (BauleyCivic)
I love Honda MTF as well. My tranny has 254,000miles on it and it used to grind really bad in second and thrid. I put in MTF about 3000miles ago and thus far it's pretty much gotten rid of all the grinds under normal driving conditions.
Just remember, MTF will help, but it's a bandaid that'll temporarily fix the problem.
Old 05-04-2005, 09:34 PM
Default Re: Will GM Syncromesh fix my 3rd gear grind? (litterbox)
i have been using honda mtf, and yes i do agree that is does indeed shift VERY nice for the first few days. But somehow after using it for a while...my **** is grinding like crazy. Plus when I drained the Honda MTF for some reason...it came out cloudy and thin instead of how it looked like 10,000 miles ago.
Old 05-04-2005, 09:39 PM
The Internet Tough Guy's Avatar
synchro mesh won't do ****. replacing your motor mounts will.
Old 05-04-2005, 09:42 PM
dc2vu's Avatar
I used GM syncromesh on my tranny...i could feel a slight difference of what i was at...easier to get into gear and all that...no experience with MTF yet because i used GM as my first tranny fluid change
Old 05-04-2005, 09:59 PM
Default Re: Will GM Syncromesh fix my 3rd gear grind? (The Internet Tough Guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Internet Tough Guy &raquo;</TD></TR><TR><TD CLASS="quote">synchro mesh won't do ****. replacing your motor mounts will. </TD></TR></TABLE>
i see...i think imma go buy some $500 hasports mounts and maybe that'll get rid of my 3rd gear grinding!
Old 05-04-2005, 10:03 PM
B2FiNiTY's Avatar
sycromesh, friction modified!
Don't even try the normal stuff.
Old 05-04-2005, 10:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 &raquo;</TD></TR><TR><TD CLASS="quote">i see...i think imma go buy some $500 hasports mounts and maybe that'll get rid of my 3rd gear grinding!</TD></TR></TABLE>
just get the es inserts for 20 bucks, or some jimfabs for 100. better yet just fill them all up with window weld for almost nothing.
Old 05-04-2005, 10:12 PM
Multi-paradigm
Good ol' Screwtape's Avatar
Syncromesh = bandaid =
If parts are worn, fix it the right way if you really give a ****.
Old 05-04-2005, 10:22 PM
Default Re: Will GM Syncromesh fix my 3rd gear grind? (Screwtape:)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Screwtape: &raquo;</TD></TR><TR><TD CLASS="quote">Syncromesh = bandaid =
If parts are worn, fix it the right way if you really give a ****.</TD></TR></TABLE>
imma take my d16a6 tranny to the shop and have them fix it for a leg. OR i can go to Hmotors or something a buy a new used one for $100.
Old 05-04-2005, 10:24 PM
komat's Avatar
the whole tranny for $100?
Old 05-04-2005, 10:27 PM
Multi-paradigm
OR i can go to Hmotors or something a buy a new used one for $100.</TD></TR></TABLE>
thats the spirit i didn't mean to sound all anti-syncromesh (even though i am)- so by all means use it if you want a cheap, quick fix. well, it's not a fix...it's more like a "cover-up" and a temporary one at that.
but lucky you for being close to HMO. I live in SD, and i hate having to drive up there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">the whole tranny for $100?</TD></TR></TABLE>
yeah...usually people don't buy trannies piece by piece...
Old 05-04-2005, 11:26 PM
JDM SLICK's Avatar
depends on how bad or worn your synchros/gears are...like what was said before, gm=bandaid.
It kinda cured my 3rd gear grind on high rpms, but don't get your hopes up that it'll do "wonders"
Old 05-06-2005, 05:29 PM
dc2vu's Avatar
Default Re: Will GM Syncromesh fix my 3rd gear grind? (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">sycromesh, friction modified!
Don't even try the normal stuff. </TD></TR></TABLE>
yeah thats what i used
Old 05-06-2005, 06:50 PM
Default Re: Will GM Syncromesh fix my 3rd gear grind? (dc2vu)
Just put in some GM Syncromesh FM and that **** works! Fixed my 3rd gear grinding instantly! Thanks Syncromesh!
EGk3nrock
79
12-10-2007 12:49 PM
90gs
11-01-2006 12:37 PM
ek9 ferio
01-28-2006 11:26 AM
redracer1024
01-25-2006 12:13 PM
743power
10-09-2003 11:41 PM
Quick Reply: Will GM Syncromesh fix my 3rd gear grind?
