car leaking water...any ideas?
Old Sep 6, 2006 | 06:00 PM
shoebox's Avatar
Default car leaking water...any ideas?
it is leaking onto the driver side carpet. is there a gutter system by the driver side A piller? I put a full pillar pod in and I think I may have screw into it if there is one there. Is there also one under the wiper cowl? cause I have these trees in my yard and they have a **** load of the helicopter things that fall and get stuck right there
Old Sep 6, 2006 | 06:06 PM
shoebox's Avatar
Default Re: car leaking water...any ideas? (shoebox)
and I should add that I dont drive in the rain, it just sits there.
Old Sep 6, 2006 | 08:54 PM
shoebox's Avatar
ttt
Old Sep 6, 2006 | 08:57 PM
ekcivic9's Avatar
is there a bad seal from your antenna?
Old Sep 6, 2006 | 09:01 PM
shoebox's Avatar
Default Re: (ekcivic9)
that could be it, I am going to check that tomorrow, any other ideas?
Old Sep 6, 2006 | 09:40 PM
13BT's Avatar
window moulding trim probably? had a piece of mine fly off and im taking in water, just a little though.
Old Sep 6, 2006 | 09:54 PM
shoebox's Avatar
Default Re: (13BT)
all of my trim is in tacked. Now I didn't drive it that much last winter, so I don't know when it started to do it, but **** it is annoying and I just got new carpet
Old Sep 6, 2006 | 10:39 PM
EJAYATE's Avatar
I Deliver
Default Re: (shoebox)
I bet that rain last weekend owned you Maybe have a friend spray you down with a hose and check where it leaks
Old Sep 7, 2006 | 06:56 AM
shoebox's Avatar
Default Re: (B2CivMan)
I did get own just sitting there. that is what I will do. Thanks gentlemen
Old Sep 7, 2006 | 07:39 AM
mike1114's Avatar
This is a known problem with EG civics, there is a service bulletin about it.
rain runs down the window, into the plastic cowl where the window meets hood. Behind the quarter panel the chassis is sealed together there with just sealant. After 10+ years of vibration, the sealant doesn't do so hot.
Take off your quarter panel, strip off all the old sealant you can and now reaseal as much as you can.
Follow the service bulletin.
Good luck, I followed bulletin and water is still getting in. Maybe its on the other side of the car, I haven't pinpointed it yet.
The rear hatch is also another prone spot to leaking.
Old Sep 7, 2006 | 10:49 AM
shoebox's Avatar
Default Re: (mike1114)
Idk, I know that it doesn't leak in the hatch, but I am worried about it getting my brand new carpet all wet
Old Sep 7, 2006 | 10:54 AM
instructor74's Avatar
if you have a sunroof there are drain tubes that run down the pillers
Old Sep 7, 2006 | 10:56 AM
deckster333's Avatar
Sunroof?
There is two small tubes that run down from the power sunroof through the A-Pillars and drain water from the sunroof out the side of the frame near the lower door hinges. If the tube is damaged, water running over the sunroof will drain directly into your floor.
jolt-tsp's Avatar
Default Re: (instructor74)
My brothers Accord had a similar problem with A/C condenstation getting caught up in a clogged hose. Shoved a coat hanger down the hose a few times, problem was solved.
Old Sep 7, 2006 | 08:14 PM
shoebox's Avatar
Default Re: (jolt-tsp)
I don't have a sunroof, and I don't have AC. Are there still those 2 tubes even if I don't have a sunroof?
Obese
Apr 24, 2010 05:50 AM
mnmsddy
Dec 18, 2009 01:41 PM
SC-MK1
Apr 8, 2005 05:46 AM
whagkangmakulet
Feb 26, 2002 01:26 AM
