wide open throttle symptoms, what could it be ?
Old Sep 6, 2006 | 11:56 AM
Offer's Avatar
Default wide open throttle symptoms, what could it be ?
I still haven't figured out this problem yet, ever since i installed my edelbrock kit i've always had this problem, whenever i reach wot, the car stumps and isnt making power, so i cant reach peak boost, so i'm always stuck tryin to keep the throttle at 75% which wont take me more than 6 psi, i know it could be many things.
I'm just tryin to run a steady 8-9 psi, fuel pump should be good till 200hp, Anyways, you guys tell me
What could be the main causes of this, i hope I can get this figured out like that i could get it off my mind, thanks !
Old Sep 6, 2006 | 12:00 PM
93turbo16's Avatar
Default Re: wide open throttle symptoms, what could it be ? (Offer)
What engine management? Sounds to me like you are leaning out..
Old Sep 6, 2006 | 12:43 PM
Offer's Avatar
sorry i forgot to mention, i'm running the edelbrock turbo kit on my d16y8, it uses it's own fuel managment called the link, it's tuned till 10-11 psi, and the tuning is done pretty well said by some tuners, so i wouldnt think that it's leaning out, it happens as soon as i step on it, maybe like a fuel pump or electronics issue
anyways, you guys let me know
Old Sep 6, 2006 | 01:24 PM
93turbo16's Avatar
Default Re: (Offer)
Either way, I think you should ditch it and run crome/uberdata. That kind of stuff is known to cause problems.. especially and obviously (if it isn't hooked up right).
I had problems with a turbonetics kit and there engine management.
But I do think I know what system you are talking about.. but it still needs to be tuned. It has a little handheld screen with up and down arrows?
Old Sep 6, 2006 | 04:47 PM
Offer's Avatar
even though it might have to be tuned for 8 psi+, that still isnt the problem because even without a boost controller, running stock settings at 5 psi, the same would still happen at wot so, so guarantee the issue is elsewhere, can anyone point out what you think might be wrong ?
Old Sep 7, 2006 | 07:19 AM
Hondacivicnut's Avatar
Default Re: (Offer)
Are you using a wideband 02 kit???
Old Sep 8, 2006 | 04:42 AM
Offer's Avatar
nah i'm not using using a wideband, but anyways, the problem is that the link system is just a basemap, and it just isnt tuned properly for my set-up, although some people are lucky and it works pretty good with their setup, so i will be getting new managment during the wither, maybe hondata or something
Old Sep 9, 2006 | 07:10 PM
UNKNOWN_MEMBER's Avatar
Default Re: (Offer)
could be your ecu running into limp mode. it happened to my friend, missing link fixed it for him, map sensor was throwing a code.
boosted94gsr
Mar 12, 2024 07:53 PM
Dat1BVtecN
Aug 1, 2008 05:27 AM
blackdude
Nov 19, 2004 03:37 PM
boosted_dc2
Aug 28, 2003 06:49 PM
SiSoul
Nov 26, 2002 01:36 PM
