car makes no power under load.................help?????
Old Sep 5, 2006 | 10:35 PM
dwaynevkao's Avatar
Default car makes no power under load.................help?????
dont even know where to start.... alright, i was driving home on night and had the pedal to the ground all the way past 100mph, and then i backed off the gas to slow down and when i put my foot back on the gas the car felt like it had lost power.
i did a whole lot of tests to try and diagnos the prob. I ran a compression test and got 180 across all 4. checked timing and was on the dot. replaced the dizzy cap, rotor, igniter and coil. replaced fuel filter. replaced spark pluggs and wires. replaced ecu. Still no change.
it runs and sounds fine on idle and even when im driving like a normal person would, but if i punch it the car dont go nowhere i just hear a loud roar from the intake and when i shift gears at high rpm it backfires. i also checked the spark and all 4 got spark. fuel pressure is fine.
im just lost.............maybe bent valves? bad injectors? bad dizzy?
Modified by dwaynevkao at 11:48 PM 9/5/2006
Modified by dwaynevkao at 11:51 PM 9/5/2006
Old Sep 5, 2006 | 11:00 PM
hatch96y7's Avatar
Default Re: car makes no power under load.................help????? (dwaynevkao)
maybe the clutch has gone out or need a new pressure plate not sure
Old Sep 5, 2006 | 11:02 PM
dwaynevkao's Avatar
Default Re: car makes no power under load.................help????? (hatch96y7)
brand new clutch and pressure plate.
Old Sep 5, 2006 | 11:26 PM
XLR8 GS-R's Avatar
It sounds like its running rich? But I dont know why it would happen right after you passed 100. Is there a check engine light?
Old Sep 6, 2006 | 04:33 AM
JSPECSIR's Avatar
Default Re: car makes no power under load.................help????? (XLR8 GS-R)
if its not missing, and its backfiring, id say running rich too. which would deff. kill power under load. kinda like when you load a fresh basemap on your ecu. the more you push the pedal the more it slows down cause its dumping way to much fuel.
Old Sep 6, 2006 | 06:56 PM
dwaynevkao's Avatar
no check engine lights
dwaynevkao's Avatar
Default Re: car makes no power under load.................help????? (JSPECSIR)
when i checked the spark plugs they were white, so i guess its running lean and also the plugs dont smell of gas at all
Old Sep 6, 2006 | 07:26 PM
allstarimports1's Avatar
what motor? i live in palm beach...
Old Sep 6, 2006 | 07:28 PM
dwaynevkao's Avatar
Default Re: car makes no power under load.................help????? (allstarimports1)
b16 head stock and b20 block stock
jawsiiv
Aug 16, 2008 12:26 PM
slickciv
Feb 15, 2007 01:42 PM
Gsr94black
Feb 12, 2007 01:18 PM
CloseCall
Apr 19, 2003 12:36 PM
