D16Y8 WHATS THE BIGGEST BORE I CAN GO WITH
Old Sep 5, 2006 | 07:14 PM
project89sicrx's Avatar
Default D16Y8 WHATS THE BIGGEST BORE I CAN GO WITH
i just dropped off my y8 at the machine shop today to get resleeved with darton wet sleeves. i was wondering whats the biggest bore i can go with on them?
Old Sep 5, 2006 | 07:21 PM
EK FLY's Avatar
Default Re: D16Y8 WHATS THE BIGGEST BORE I CAN GO WITH (project89sicrx)
to tell u the tru man but building ur single cam for power is like trying to fill a pool with a squirt gun but u go ahead with u will make more power with forged internally b serie
Modified by TURBO-WAWA at 6:13 PM 9/6/2006
Old Sep 5, 2006 | 07:26 PM
redEG92's Avatar
Default Re: D16Y8 WHATS THE BIGGEST BORE I CAN GO WITH (TURBO-WAWA)
why you say that about a single cam?
Old Sep 5, 2006 | 07:30 PM
Soccerking3000's Avatar
Default Re: D16Y8 WHATS THE BIGGEST BORE I CAN GO WITH (redEG92)
well i have my z6 at 78mm, if you are building for boost which i think you are, i would get 76mm bore so if you screw up and blow something up youcan always bore it out some and start over
Edit: and he said that because he is ignorant
Old Sep 5, 2006 | 07:35 PM
Boostage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBO-WAWA &raquo;</TD></TR><TR><TD CLASS="quote">to tell u the tru man but building ur single cam for power is like trying to fill a pool with a squirt but u go ahead with u will make more power with forged internally b serie </TD></TR></TABLE>
LMAO
Old Sep 5, 2006 | 07:38 PM
GiNuWiNe's Avatar
When giving advice.. english helps.
Old Sep 5, 2006 | 07:43 PM
Default Re: D16Y8 WHATS THE BIGGEST BORE I CAN GO WITH (GiNuWiNe)
and to think he is 21 and can't spell, nor complete a sentence
Old Sep 5, 2006 | 07:49 PM
lol, we will see when it runs down the track. plus i love the torque if u notice most d series motors on dynos have high torque. the torque is closer to the hp level then a b series. i've already built my full race head which actually flows better then a b series stock head "yes it is true flame on me if u want to". heres everything i've done to the head. it has been ported & polish on a flow bench for full race to get that perfect flow for the turbo to spool all the way to the redline. i also have my STR IM and my STR TB which both are ported and polished to perfection . i have a blox cam but now, i'm trying to figure out which cam to use instead of that one. aem cam gear, ferrea valves, ferrea dual valve springs and ferrea retainers with brand new oem valve guides. and also my fuel system, but i'm not going to get into that and all the othere goodies i have for it . but all i need now is to figure out what i need for the short block
Modified by project89sicrx at 9:09 PM 9/5/2006
Modified by project89sicrx at 9:11 PM 9/5/2006
Old Sep 5, 2006 | 07:54 PM
well to your original question, the biggest bore i have seen is 79mm, however i would only suggest that for an NA vehicle as the sleeves would be too thin even with aftermarket sleeves for a boosted application, like i said i would run a 76mm bore so it gives you room for error in case something gets screwed up and you need to rebore it.
Old Sep 5, 2006 | 07:58 PM
Default Re: D16Y8 WHATS THE BIGGEST BORE I CAN GO WITH (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">well to your original question, the biggest bore i have seen is 79mm, however i would only suggest that for an NA vehicle as the sleeves would be too thin even with aftermarket sleeves for a boosted application, like i said i would run a 76mm bore so it gives you room for error in case something gets screwed up and you need to rebore it.</TD></TR></TABLE>
yea the motor is going to be turbo'd . thanks for your help
Old Sep 6, 2006 | 06:51 AM
RyanEJ8's Avatar
Dumbass can't even make a sentance.
Old Sep 6, 2006 | 07:41 AM
ladysman's Avatar
I have 78.5mm bore.
I would go with either 75.5 or 76.
Old Sep 6, 2006 | 07:51 AM
M.A.R.C.'s Avatar
Default Re: D16Y8 WHATS THE BIGGEST BORE I CAN GO WITH (ladysman)
mine was @ 77mm but highest i'd go on boost is 78mm.
one thing to think about too is the availability of headgaskets. it took me forever to get a damn headgasket when i had to change mine.
Cometic happened to be on BO on all damn HG's
RS machine took a month to cut an oem one to 77mm (this was when they were changing owners or whatever though)
Old Sep 6, 2006 | 04:52 PM
redEG92's Avatar
Default Re: D16Y8 WHATS THE BIGGEST BORE I CAN GO WITH (RyanEJ8)
ill be sure to take advice from turbo wawa next time
Old Sep 6, 2006 | 05:01 PM
SL0WEGG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanEJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
Dumbass can't even make a sentence.</TD></TR></TABLE>
Old Sep 6, 2006 | 05:15 PM
EK FLY's Avatar
Default Re: D16Y8 WHATS THE BIGGEST BORE I CAN GO WITH (boostedej1)
yea guys I know the truth hurt muhahhaah
Old Sep 6, 2006 | 07:40 PM
wow you are such a tool
Old Sep 7, 2006 | 05:17 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBO-WAWA &raquo;</TD></TR><TR><TD CLASS="quote">yea guys I know the truth hurt muhahhaah </TD></TR></TABLE>
You made my sig for being such a jackass.
Old Sep 7, 2006 | 05:49 AM
PrecisionH23a's Avatar
forged internally FTW!
WanderingSamurai830
12
Feb 21, 2007 02:50 PM
gsu
12
Feb 16, 2006 10:32 AM
93-Z6-CX
Aug 18, 2005 11:07 AM
I8ayellowcrayon
18
Feb 20, 2005 08:27 PM
