How much oil to put into a turbo GSR
Recently installed a turbo into my gsr and I wanted to do an oil change. Should i be putting in a little extra oil into the car since its turbo now? Or should i put in the same amount that any other gsr would use? About how many quarts?
Yeah , full on the dip stick is always safe. Of course a little bit of your oil will now be inside the oil feed/turbo/oil drain rather than in the motor when running , but its better to be slightly low than over at all.
