How to adjust hood release?
If it's anything like the trunk release....
then the cable should just unclip from inside the hood, and it has several other slots where you can re-clip it. just pull the cable further away from the latch.
if it's not like the trunk release....
then i don't know
then i don't know
i have the same issue however i do not think it is the cable because i have adjusted it multiple times and it does not help in my opinion it is most likely the spring that helps pop the hood up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teler86 »</TD></TR><TR><TD CLASS="quote">i have the same issue however i do not think it is the cable because i have adjusted it multiple times and it does not help in my opinion it is most likely the spring that helps pop the hood up
x2 Try screwing the bolt that the spring's on a little tighter so that it can "pop" better. You might have to use a ****-ton of WD40 and elbow grease to get that sucker turned, but it'll move. You just need a large-bladed flathead screwdriver.
</TD></TR></TABLE>x2 Try screwing the bolt that the spring's on a little tighter so that it can "pop" better. You might have to use a ****-ton of WD40 and elbow grease to get that sucker turned, but it'll move. You just need a large-bladed flathead screwdriver.
anymore ideas? I also have the same problem on the crx i just bought.
I did read somewhere that someone added a couple washers under the 4 bolts that hold that front metal panel between the headlights but that was because he had an SIR hood that wouldn't latch. Maybe that will work but I don't know, I can't get my damn hood open to try.
madmanmulligan
May 21, 2006 09:32 AM
sidewayz
Mar 12, 2003 07:28 PM
