Idle problems on my eg
Old Sep 2, 2006 | 06:20 PM
hatch_dude's Avatar
Default Idle problems on my eg
I installed an obx throttle body spacer on my si. When I first started the car it would idle at about 2500 now it will rev from 1500 to 2500 back and forth like a bad throttle position sensor. I was real careful when I had the throttle body off. I cleaned it up real carefully on the throat and polished the throat up to about a half inch from the butterfly. Blew everything out with air before I reinstalled it. Now I have problems. And its not the cable being to tight...............Any helpful tips would be great............Thanx
Old Sep 2, 2006 | 06:32 PM
hondamark35's Avatar
Default Re: Idle problems on my eg (hatch_dude)
i don't know much about that spacer, like if it comes with an extra gasket... but i would bet that you have a vaccum leak at the throttle body. if you spray some TB cleaner or brake cleaner on the TB area and the idle evens out then that'll confirm a leak. (oh, when you spray make sure you have the intake tube on and tight and if you have a cone filter be sure not to get any spray on it)
phelpsj2
Nov 3, 2011 02:35 PM
thewrai6th
Sep 13, 2011 05:19 PM
bmxfelon420
Mar 20, 2010 04:11 PM
BB1 H22A LUDE
Feb 25, 2008 01:55 PM
